Author Topic: WTH is this  (Read 1329 times)
Offline Sdsbassist
  • Gus, Austin, MN.
WTH is this
« on: August 09, 2018, 08:36:55 PM »
WTH?
Attached jimmy rigged to RH controls.
Sent from my SM-N910V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: WTH is this
« Reply #1 on: August 09, 2018, 08:37:27 PM »
Pics
Gus, Austin, MN.
Re: WTH is this
« Reply #2 on: August 09, 2018, 09:11:33 PM »
Are you referring to the electrical junction box off a CB750F/F1 that is in your right hand?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: WTH is this
« Reply #3 on: August 09, 2018, 09:13:29 PM »
Ya. Standard thing? It's gawdy and I figured I could do without it. It ran to the started switch or kill switch deal?
Gus, Austin, MN.
Re: WTH is this
« Reply #4 on: August 09, 2018, 09:54:27 PM »
It is where the wires from your bars connect to the wiring harness. Next to the horn but on the left side down below the steering neck. There is a "tab" that juts out forward that it attaches to.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: WTH is this
« Reply #5 on: August 10, 2018, 05:20:26 AM »
Gotcha. So that big mess of hanging wires all goes there. Another F quark!
Gus, Austin, MN.
Offline emlupi
Re: WTH is this
« Reply #6 on: August 10, 2018, 06:44:57 AM »
As I understand it, the "F" headlight bucket is smaller than the "K", so Honda added that electrical junction box to make up the connections.
Offline Bankerdanny
  • Endeavor to persevere
Re: WTH is this
« Reply #7 on: August 10, 2018, 06:55:53 AM »
If you have an F0 or F1 with the standard headlight/turn signal bracket thing you can't fit a K model headlight shell (I checked). Without that box in the photo the wires will just dangle in front of the engine.
Your signature says you have a K bike. Did you recently acquire an early F also?
« Last Edit: August 10, 2018, 06:57:43 AM by Bankerdanny »
Offline Bankerdanny
Re: WTH is this
« Reply #8 on: August 10, 2018, 06:59:56 AM »
Here's mine right after I reconnected all the wiring.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: WTH is this
« Reply #9 on: August 10, 2018, 07:12:38 AM »
That's really helpful! It had obviously been heavily modified.
Gus, Austin, MN.
Offline Bankerdanny
Re: WTH is this
« Reply #10 on: August 10, 2018, 08:32:18 AM »
I wonder if someone had access to an F model harness and swapped that in. The way the wires are set up in the F harness switching to a K setup with all the wires in the headlight bucket would be a pain.
Do you have the K2 style 4 warning lights between the bar clamps or an F/K7-K8 5 light dash between the gauges?
Replacement harnesses are surprisingly affordable. If you have the K2 warning light setup then I would find a replacement front harness for that, if you have the F later K style then I would look for a K7/8 harness that will work with your dash but hide the connections in the headlight bucket rather than the frame box.
Nevermind, I found your post in the project section, you picked up a '75 F0.
« Last Edit: August 10, 2018, 08:33:52 AM by Bankerdanny »
