Author Topic: Did Sandcast and early KO have different E Starters ?  (Read 1023 times)
« on: August 09, 2018, 11:36:19 PM »
I have the electric start motor out of  #10,1++. ....and I got to say , it does look different.
 But I could not find any info.
 Anyway if someone has  to have, I may be persuaded.
 Will try to get a few pics.
« Last Edit: August 10, 2018, 01:13:08 AM by 754 »
Offline trigger
  • Engines built on reputation, not advertising.
Re: Did Sandcast and early KO have different E Starters ?
« Reply #1 on: August 10, 2018, 12:35:46 AM »
If you are on about the starter motor? Then yes  ;)
Offline kmb69
« Reply #2 on: August 10, 2018, 02:53:17 AM »
I'm not aware of that.
Pics please.
Online Don R
« Reply #3 on: August 12, 2018, 06:47:59 PM »
hmmm, I have a no number replacement engine taken from a sandcast, and one from a diecast. I may need to check the starters.
« Reply #4 on: August 13, 2018, 09:29:16 AM »
Casting is machined different on spline end, its a circle where the bolt goes in, most are a rectangle.
