Author Topic: Erratic Points  (Read 865 times)
Offline lymbic
Erratic Points
« on: August 19, 2018, 10:11:02 AM »
Replaced 76 CB550F points with cheap ones from 4into1. 2-3 is firing much more erratic than 1-4 (see link). 2-3 has a brighter arc that’s all around the contact surfaces where 1-4 is consistently in the center of the surfaces. The old points that I replaced had a fixed post (the fulcrum of the points), new points have a removable post which was loose compared to 1-4. This was causing problems holding a gap and 2-3 wouldn’t fire after a short amount of run time. I JB welded this post on 2-3 and it’s holding a gap well now, but I don’t like the visual difference between both sets.
All four cylinders are firing pretty well under idle, not so well past 1/8 throttle, but I believe that’s a carb issue I’ve got to sort out yet.
Do y’all think this erratic arcing is going to cause problems down the road? Suggestions on a better set of points I should get? Don’t really want to go with electronic ignition if I can help it. Thank y’all
https://imgur.com/gallery/fZmsjDG
1976 CB550F Super Sport
Offline Deltarider
Re: Erratic Points
« Reply #1 on: August 19, 2018, 10:21:06 AM »
I'd start with interchanging the condensers (easy) and see if the arcing follows. If so, abandon that condenser.
CB500K2-ED Excel black
Offline brewsky
Re: Erratic Points
« Reply #2 on: August 19, 2018, 10:21:20 AM »
Looks like bad condenser on 2-3,....I wouldn't trust JB weld on a set of points
OOPS! Delta beat me 2 it
« Last Edit: August 19, 2018, 10:25:21 AM by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline lymbic
Erratic Points
« Reply #3 on: August 19, 2018, 12:49:51 PM »
Swapped condensors. Y’all are correct, spark followed condenser.
https://imgur.com/gallery/0O0Xmdv
Put one of the old condensors on and bike is running great.
Any brand recommendations for points and condensors? Got this kit https://4into1.com/tune-up-kit-honda-cb500k-cb550/ and two out of four were bad.
« Last Edit: August 19, 2018, 03:03:58 PM by lymbic »
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Erratic Points
« Reply #4 on: August 19, 2018, 06:33:22 PM »
I just watched your video, and I know the quality of the aftermarket points has been dsicussed before, but if you watch the points on the right side, you can see that they're not pivoting on the post properly. I'm not sure how you were able to properly set the gap!
......Paul
