Author Topic: Total Caliper Confusion CB750f  (Read 3677 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: August 25, 2018, 08:24:40 AM »
So, I've been trying to research the correct items for myself here but I am falling misrably short.
I have a 750f model. From what I've read there was a few discrepancies between the F and K front calipers of that year.
My last attempted ended up with the rotor hitting the arm.
Can anyone help me with interchangeability of the calipers and arms for the early model Fs?
Sent from my SM-N910V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: Total Caliper Confusion CB750f
« Reply #1 on: August 25, 2018, 08:36:08 AM »
That's a 550 caliper. They look similar to the F0,F1,K7 and K8 calipers, but are smaller and fit a 275mm rotor instead of the 750 295mm rotor. The 550 has a 38mm piston, while the caliper you want has a 42.8mm piston. You can use a K3-K6 finned caliper and matching arm, but they have a smaller 38mm piston.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: August 25, 2018, 08:37:49 AM »
Amazing. I dug through my pile and found an arm that clears the rotor.
Success!
I'm guessing the caliper you describe is going to be tough to find. What other models is it interchangeable with? With the a model?
Gus, Austin, MN.
« Reply #3 on: August 25, 2018, 08:46:06 AM »
The A model *may* have also used the larger caliper. The arms are not interchangeable between the different 750 calipers. Post a pic of the arm.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #4 on: August 25, 2018, 09:42:40 AM »
See
Gus, Austin, MN.
« Reply #5 on: August 25, 2018, 09:57:29 AM »
 I'm a big fan of the double F0/1 front disc. I even cut up two rotor fenders and made a right side fender.
« Reply #6 on: August 25, 2018, 10:28:54 AM »
That is the correct F0/F1 K7/K8 arm; it's thicker in the area where the caliper halves mount, while the early arms are flat. If you look at the 550 caliper, you'll notice the mounting bolts are closer together than the 750, so that's one way to identify which caliper you're looking at.
Online bryanj
« Reply #7 on: August 26, 2018, 08:06:03 AM »
The F1 caliper is the rarest and most difficult to find but I believe Dave Silver has had some replicas made
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #8 on: August 26, 2018, 09:12:42 AM »
Think I found one...
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #9 on: August 27, 2018, 02:44:36 PM »
On the correct caliper, what should be the distance bolt hole to bolt hole?
Gus, Austin, MN.
« Reply #10 on: August 27, 2018, 05:31:09 PM »
The center-to-center distance of the 750 caliper bolts is 50mm, or about 1.97". The 550 caliper spacing is 42mm, or about 1.65".
« Reply #11 on: August 27, 2018, 05:48:06 PM »
You should be able to sell the 550 caliper easily along with it's mounting hardware/brackets.
« Reply #12 on: August 29, 2018, 06:34:52 PM »
This Honda 45100-392-003 CALIPER ASSY. (TOKIKO) fits the following models and components:
Honda Motorcycle 1976 CB750A A - 750 HONDAMATIC FRONT BRAKE-CALIPER
Honda Motorcycle 1976 CB750F A - 750 SUPER SPORT FRONT MASTER CYLINDER + FRONT BRAKE CALIPER
Honda Motorcycle 1977 CB750K A - 750 FOUR K FRONT BRAKE-CALIPER
Honda Motorcycle 1978 CB750K A - 750 FOUR K FRONT BRAKE-CALIPER
Honda Motorcycle Models with no year CB750F A FRONT MASTER CYLINDER + FRONT BRAKE CALIPER
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #13 on: August 30, 2018, 06:36:31 PM »
I just snipped this lot off ebay for a cool 40 bucks. Looks promising... definitely 2 inches between bolts. Figure between that, the arm and the switch and cylinder I'm bound to come out ahead.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #14 on: September 01, 2018, 09:47:10 AM »
Local yard found these.....they look smaller?
Gus, Austin, MN.
« Reply #15 on: September 01, 2018, 02:34:46 PM »
the smaller ones are 500/550 and will not fit or function on a 750
