Author Topic: Torque settings  (Read 2072 times)
Offline topgun
Torque settings
« on: October 07, 2018, 12:15:53 PM »
Hi Guys, I am chasing the Torque settings for Mtc conrods for my cb 750 I have e-mailed Mtc but no reply yet I was hoping one of you guys could help me out Cheers
Offline Bill/BentON Racing
    • BentON Racing
Re: Torque settings
« Reply #1 on: October 08, 2018, 04:07:58 AM »
Don't have specs,  but good bolts should be @ 30 lbs I'd think.
BentON Racing Website
BentON Racing Facebook
Re: Torque settings
« Reply #2 on: October 08, 2018, 06:20:06 AM »
If you have a stretch gauge I'd say .005"
Offline topgun
Re: Torque settings
« Reply #3 on: October 08, 2018, 11:56:56 AM »
Thanks for your input guys I went up to 20lbs and the plastigauge looked good  but will check it with 30 Mtc did not have any info available Cheers Tony
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
Re: Torque settings
« Reply #4 on: October 08, 2018, 06:30:21 PM »
Agreed. Bolt stretch is easy to check, and isn't a friction dependent measurement. The bolt's stretch provides the clamping force. Different thread / underhead lubricants can produce wildly varying bolt stretch at the same torque setting. In many applications an appropriate length micrometer can suffice.
Here is a sample I have of AJPE aluminum rod installation instructions, it give the manufacturers recommended assembly lube, torque, and bolt stretch. In this case, bench testing shows 95 ft/lbs on my torque wrench produces the desired stretch when lubed with 70wt Redline oil.
FYI: In the case of modern Top Fuel rods, even if you grossly over torqued them to like 200+ ft/lbs, you will break the bolt before you strip out the threads. Not something I'd try with my Golden Rods.  ::)
EDIT: Sorry, can't get the photo to orient itself upright on this page.
« Last Edit: October 08, 2018, 07:03:54 PM by NitroHunter »
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Re: Torque settings
« Reply #5 on: October 09, 2018, 03:13:42 AM »
Hopefully changed orientation
« Last Edit: October 09, 2018, 03:35:54 AM by PeWe »
Offline topgun
Re: Torque settings
« Reply #6 on: October 10, 2018, 11:54:14 AM »
Thank you Nitro Hunter for the info  Cheers Tony     ps and you too PeWe
