Author Topic: Need help with Cognito rearset bracket  (Read 1513 times)
Offline rangerdave1
« on: October 12, 2018, 06:06:11 PM »
I have Cognito rearset brackets and tonight, I learned that the pivot bolt is to short. Now these brackets are similar to other brackets in how they mount to the bike.. They use the pivot bolt and engine bolts to mount to the frame. The issue is that the extra thickness of the brackets doesn't allow for the nut to thread on because the bolt is not long enough. The brackets are about 3/8" thick each. I am considering milling down where the bolt is on the bracket however unless I removed almost all the thickness, I don't think it will be enough any way
I'm sure others have had this issue and wondering what have been the solution.
1. Are there longer pivot bolts available? possibly from another yeah/model..
2. Should I get my stock pivot bolt lengthened at a machine shop?
And before anyone ask why I did not get Cognito's aluminium bracket, I chose the steel version because I felt their aluminium although beautiful, would not fit the look I am trying to achieve. I am trying to avoid a modern look on this bike. The rearset in the photo is not likely the one I will keep on the bike.
Thanks!
Online seanbarney41
Re: Need help with Cognito rearset bracket
« Reply #1 on: October 12, 2018, 06:24:23 PM »
I think a swingarm pivot from a 77/78 F will get you the length needed as this bike uses the swingarm pivot as mounts for rather thick aluminum plates that mount the passenger pegs(pass. pegs removed in this pic).20181006_154627 by Sean Barney, on Flickr
I have a similar set of those steel Cognito brackets for a 550 and they are easily twice as thick as necessary...unless going motocrossing and you weigh about 400 pounds
« Last Edit: October 12, 2018, 06:26:53 PM by seanbarney41 »
Offline rangerdave1
« Reply #2 on: October 12, 2018, 06:31:02 PM »
Oh that might be exactly what I need.
Does any one have a 77/78 pivot bolt they could measure the length??
Yes the Cognito bracket is very thick and I agree is likely twice as thick as it needs to be. But it is very nice.
« Reply #3 on: October 12, 2018, 10:20:48 PM »
They should just tap one side to fit the swingarm bolt when they make them.
 If you have the taps, and a lathe, you could make an insert or a nut.
Offline rangerdave1
« Reply #4 on: October 13, 2018, 08:39:05 AM »
They do. The OPs picture is NOT a Cognito bracket.
I bought them from their website and got them yesterday.  ::)
https://cognitomoto.com/collections/rearsets/products/cb750f-rearset-brackets-gsxr-master-cylinder-conversion
