Author Topic: HOW to Engine CB750 '73 Upgrade for street use only  (Read 6812 times)
Offline Ilja
Re: HOW to Engine CB750 '73 Upgrade for street use only
« Reply #25 on: November 22, 2018, 02:32:34 PM »
Where have all old ported heads from the 70-80's gone?
It must be many collecting dust and no longer used waiting for a seat and valve job.
I think so... I have at least two heads for every bike I own. XD
... but I just saw this: https://www.ebay.co.uk/itm/Oversized-Intake-Valves-Honda-Four-CB-750-K-SOHC-69-77-34mm/273093318769?_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20170221122447%26meid%3D013483a1238346a380b88bcdd3d85638%26pid%3D100752%26rk%3D5%26rkt%3D6%26sd%3D273093320079%26itm%3D273093318769&_trksid=p2047675.c100752.m1982
If it's possible to install 34mm valves in the K/f1 heads, then why did they go through all the trouble for the F2 head?
I'm porting my f1 head for RS34 and am installing these 34mm valves, and then I will just run my current "cheap" 836cc flattops instead of expensive pistons. :)
« Reply #26 on: November 22, 2018, 03:01:15 PM »
Those 34mm ebay valves won't work in the f2 head....they are to long and keeper groove is different.
Offline Ilja
« Reply #27 on: November 22, 2018, 03:20:44 PM »
Yes, the F2 head also already has 34mm valves... I wanted to keep those valve sizes so was planning on buying special F2 pistons for conversion back to N/A.
But now I can just upgrade the F1 head (=K) with these valves so it's also 34mm, and install that head to get back at normal N/A compression with my current pistons instead.  :)
« Reply #28 on: November 23, 2018, 01:35:53 AM »
My K6 head got F2 in valves as an upgrade
« Last Edit: November 23, 2018, 02:34:45 AM by PeWe »
