Author Topic: Merit to this mod? - filling air screws - non stock air filter  (Read 1237 times)
Offline nixon
« on: December 29, 2018, 10:36:17 PM »
Yay or Nay to this minor mod?
http://www.hondachopper.com/garage/carb_info/idle_screw_mod/idle_screw_mod.html
could this explain why my cb750 only runs with screws all the way in?
Im using foam filters over velocity stacks ( yes i tried to fit a stock airbox!..but its an "A" with K carbs
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
Online Deltarider
Re: Merit to this mod? - filling air screws - non stock air filter
« Reply #2 on: December 30, 2018, 02:27:45 AM »
i have seen a post somewhere on this forum where the hole was soldered. Maybe Hondaman that recommended it.
I seem to remember it was Dave500 who recommended it. Don't know what type of airfilter he runs.
CB500K2-ED Excel black
« Reply #3 on: December 31, 2018, 08:12:07 AM »
If youre talking about your 750K7, and it has stock PD carbs...the IMS dont have holes.
If you have the earlier carbs, send dave500 a pm, maybe he can explain more...
« Reply #4 on: December 31, 2018, 01:45:01 PM »
you can only enrichen the drilled screws so far,even fully closed they pass air,solid ones give you full control over it,as good as jb weld might be solder is better,i run the full stock air box.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #5 on: December 31, 2018, 01:51:03 PM »
I use job on mine
Offline nixon
« Reply #6 on: January 03, 2019, 01:06:57 PM »
Thanks guys.  If the 45 slow jets don't give me control over the air screw,  I think I'll solder some up!
