Author Topic: Brake pedal question: CB750? Straight model that hits the #4 pipe  (Read 2411 times)
- Anyone that know which brake pedal this is?
It has the dot for fitment and spring bracket.
I bought it 1.5 years ago on Ebay sold to fit CB750.
Noticed after I have mounted the pipes a few days ago that brake will hit it.
My K6 pedal is curved outwards to avoid exhaust.
Yes, the K6 has wrong kick starter, K7 model  ;D
« Last Edit: January 20, 2019, 09:18:18 AM by PeWe »
Re: Brake pedal question: CB750? Straight model that hits the #4 pipe
« Reply #1 on: January 20, 2019, 01:20:18 PM »
Interesting part! I don't remember ever seeing a brake pedal that 'straight' for the 750. They always look like they had a near-miss accident with a truck when you have one in your hand, all the curves and angles they have. Being straight will certainly make it hit the #4 pipe, which is usually outside the frame.
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #2 on: January 20, 2019, 01:30:35 PM »
You will also find that the K6 right footpeg bracket is slightly longer than the K2. Why, i don't know  ???
« Reply #3 on: January 20, 2019, 01:57:51 PM »
 I seem to remember one of the "F" models was fairly straight as they pivoted in the alloy footrest plate
« Reply #4 on: January 21, 2019, 09:41:14 AM »
Very interesting info and good to know.
I'll check the footpeg which is not original Honda, it's a Yamiya version on that photo with straight pedal.
Did the F model have the spring bracket for brake switch?
I saw that some later did not have it.
OK, not even Hondaman recognized it ;) I had thoughts about eventual early version and pipe had an indent for it...
Maybe a CB500 something...?
« Last Edit: January 21, 2019, 09:42:55 AM by PeWe »
« Reply #5 on: January 21, 2019, 10:18:14 AM »
 I think early does not have the stop bracket on it.. height adjust.
 I think F model may have different splinesm the 77 and 78 K do..I think..
I also think that the brake pedal us one of the ugliest pieces on the bikem always wanted a nice clean billet one..
Offline pjlogue
« Reply #6 on: January 21, 2019, 01:11:38 PM »
With the bluing of the shaft in the first pic, I wonder if someone at some point heated it and straightened it.  No other reason for it to be blued that I could think of.  Perhaps it came off a bike with an aftermarket exhaust where it interfered and that was their solution.
-P.
« Reply #7 on: January 25, 2019, 07:26:54 PM »
-P.
That big glob of a weld on the pivot also seems non-Honda to me?
« Reply #8 on: January 25, 2019, 10:02:11 PM »
The pedal photo has reflexes coloring it. Here another photo
Offline RSchaefer
« Reply #9 on: January 28, 2019, 09:21:15 AM »
My F0 brake pedal from the factory is straight, uses the brake light spring and there is an indentation in the 4 into 1 collector for it.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #10 on: January 28, 2019, 09:52:46 AM »
Thanks! The mystery is solved :) The seller did sell a CB750 pedal.
I have the beginning of an F0 project! Let's find all other parts ;)
Offline kvikgrip68
« Reply #11 on: June 06, 2021, 11:51:38 PM »
Hi
It looks like a K7 pedal ......its more straight than the K6 pedal
Offline flybackwards
« Reply #12 on: June 07, 2021, 10:35:20 AM »
Not a K7 pedal - k7 pedal is very curvy
