Author Topic: CB550 Main Jet Holder Question  (Read 3162 times)
Offline Rocketman
« on: March 04, 2019, 02:09:15 PM »
Helping my nephew refurbish a 76 CB550.  Disassembled the carbs and found this in the #2.
Appears its purpose is to retain the main jet.  My question is, should all of the carbs have this holder? From the boogered screw heads we are not the first to open the carbs.
Re: CB550 Main Jet Holder Question
« Reply #1 on: March 04, 2019, 04:49:02 PM »
Not really a 550 guy...but I am pretty sure that there are supposed to be one in each carb.  Otherwise, the tightness of the o-ring is the only thing keeping the main jet from falling into the bottom of the bowl.
Offline jakec
« Reply #2 on: March 04, 2019, 04:56:06 PM »
There is supposed to be one in each carb because the main jet is a press-fit. There is a thread here where a guy used a spring in place of that part, if you don't want to have to buy 3.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline Rocketman
« Reply #3 on: March 04, 2019, 05:18:34 PM »
That is what I suspected.  If we can't find the three he needs will consider using a spring.  Thanks!
« Reply #4 on: March 05, 2019, 09:15:16 AM »
I may have some Martin if you need.
« Reply #5 on: March 05, 2019, 02:24:36 PM »
Offline Ms Tokyo
« Reply #6 on: September 11, 2020, 03:17:15 PM »
looking for a main jet holder if anyone has one or an explanation on how to use a spring.  thank you!!!
