Author Topic: Re-attaching speedo trim ring  (Read 3797 times)
Offline Scott S
« on: April 03, 2019, 04:40:57 PM »
 How are you guys attaching this chrome trim ring?
 It was loose at the end and I tried some 2 part epoxy. Then the whole damn thing came off! Super glue?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
AwesomeCB
Re: Re-attaching speedo trim ring
« Reply #1 on: April 03, 2019, 06:27:36 PM »
Check YouTube for how-to vids. There are at least a couple.
Offline Scott S
« Reply #2 on: April 04, 2019, 03:27:11 AM »
 I found a couple that show them un-crimping and then re-crimping the main body ring but none of them showed this separate trim ring.
'71 CB500 K0
'81 Yamaha XS650
« Reply #3 on: April 04, 2019, 04:29:57 AM »
Thats because it is supposed to be in one piece, now its been cut the only thing you can do is glue it on.
Offline Scott S
« Reply #4 on: April 04, 2019, 04:51:33 AM »
 Super glue?
'71 CB500 K0
'81 Yamaha XS650
« Reply #5 on: April 04, 2019, 05:24:24 AM »
Doubt it, the only thing i know that sticks and then only temporary is fingers. I would use epoxy all the way round and hold it in with a big jubilee clip. In UK i would use araldite
Offline pjlogue
« Reply #6 on: April 04, 2019, 05:54:12 AM »
With the ring being cut and pretty mangled I would buy a new ring.  You can order one here:  https://www.cb750faces.com/cb750faces.nl/
If you want to salvage the old one I would try and get it bent back into some usable shape and then use JB weld and hold it in place with a large hose clamp being careful not to have the epoxy ooze onto the clamp.  Once it sets you will never be able to open it again so make sure everything inside is working.
The best way to open the gages is to use a old fashion pain can opener.  It's the best way I have found to bend up the underside (backside) of the crimp ring.  The hardest part is re-bending the ring back again to close up the halves.  I just rebuilt my gages for my GL1000.
-P.
« Reply #7 on: April 04, 2019, 08:59:25 AM »
Those rings are very hard to close. I have tried, gave up when lacking proper tooling pressing the ring tight.
I could not find a clamp thick and rigid enough to have around the gauges with ring on and squeeze it together with screwdriver
« Last Edit: April 04, 2019, 10:24:09 AM by PeWe »
Offline WhyNot2
  • I'm finally an
« Reply #8 on: April 04, 2019, 10:04:35 AM »
my needle wouldn't come off, slowly tried prying up, and the dayyyum thing broke right off......guess they are sh1tcan material now.......
« Last Edit: April 04, 2019, 10:27:35 AM by WhyNot2 »
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #9 on: April 04, 2019, 10:06:10 AM »
I had the same issue since I had to open mine to refinish the gauge face plates. If your not looking to keep it OE, Joker Machine has rings that are 2 piece and clamp together with small bolts, like a pipe flange. Looks great, just not stock. Borrowed that image from JM website to show you.
Offline tlbranth
« Reply #10 on: April 04, 2019, 06:44:07 PM »
Dolo - looked on the JM site but could not find the rings you mentioned. Could you point me to them? They look like just what I need.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #11 on: April 04, 2019, 08:04:19 PM »
This is the link to the JM website, they are a tad pricey. https://jokermachine.com/products/cb750-speedo-tach-clamp-rings-black. If you look around the interwebs sometimes you can find them for around $60. I got mine off fleabay from someone who was clearing inventory. They are well made though and look great.
« Reply #12 on: April 04, 2019, 10:03:06 PM »
Nice that people design parts making it easier. These rings will make it possible to service the gauge if needed. Possible to use as a quick solution until a tool can be made crimping the real rings together. On a modified bike as Café , chopper whatever the Joker rings will fit very well.
 I have NOS gauges with a very little use. since a month. Speedo needle jump around when riding.
I guess it is very happy to finally sit on a K2 it was made for after around 45 years on a shelf somewhere ;)
I have a tool in mind using c-clamp that has 2 appr 25mm wide alu or steel piececs with correct profile squeezing the ring together. Start in one position and squeeze, then open a little and move sideways 20mm and squeeze again with a little overlap until it has gone all around.
« Last Edit: April 04, 2019, 10:04:52 PM by PeWe »
AwesomeCB
« Reply #13 on: April 05, 2019, 03:01:52 AM »
I tried and failed. I even had a clamp. If I were to attempt fitting a ring again (not likely), I would make a tool for the job.
Offline Tom C
« Reply #14 on: April 05, 2019, 05:01:20 AM »
74 CB550K0
Offline Scott S
« Reply #15 on: April 05, 2019, 05:34:47 AM »
 I used some JB Weld. It ain't the prettiest, but the repair/gap is at the bottom and shouldn't be too noticeable.
'71 CB500 K0
'81 Yamaha XS650
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #16 on: April 05, 2019, 05:42:33 AM »
Found some photos of mine. I tried using JB initially but it didn't like to adhere to the chrome. I replaced the foam backing cups as well so the larger JM rings help to create tension against the foam "floating" the gauges more. Hope this helps.
Offline slikwilli420
  • Master of Disaster
« Reply #17 on: April 05, 2019, 06:35:49 AM »
I thought Marcel made new crimp rings? You would need a press with a die to crimp it on but it would look factory and last longer than epoxy.
Offline Alaxy Galaxy
« Reply #18 on: April 05, 2019, 06:49:37 AM »
Perhaps you've already seen this how-to on the web:
https://www.dimecitycycles.com/blog/honda-cb-gauge-disassembly-and-face-replacement
This is what I had used on my CB350T, and it does leave quite a bit of waviness on the bottom of the chrome ring. On the small twin, the gauges face upwards, so the bottom is quite hidden. I think the bottom of the gauges on the bigger 4s are more visible.
Offline knowsnothing
« Reply #19 on: April 05, 2019, 09:37:02 AM »
Here you go
https://jokermachine.com/collections/honda-cb750-parts/products/cb750-speedo-tach-clamp-rings-black
I have them as well.  Are they expensive, yes, are they worth every penny when you have get in and out of the speedo, absolutely
« Last Edit: April 05, 2019, 09:42:54 AM by knowsnothing »
1978 CB750k Blue - for sale
Offline Bankerdanny
  • Endeavor to persevere
« Reply #20 on: April 05, 2019, 11:18:06 AM »
He does.
When did the faces on my 550 gauges I was able to pry the rings open to get them off and then crimp them back down with needle nose pliers. HOWEVER, I will concede that when you looked closing the rings were not crimped uniformly. Since my bike wasn't a show bike I didn't care, they held the 2 halves together and that was all that mattered to me.
