Author Topic: ‘76 cb550f kick start wiring  (Read 1058 times)
Offline Noah1981
« on: April 11, 2019, 01:17:26 PM »
Hello all, I’m trying to strip down the harness for my 1976 cb550f to only what is necessary. The bike is a kick only as the starter isn’t working. I like it this way but was hoping to simplify the wiring a bit, especially since I’m running an m-unit. Can I skip the solenoid in this scenario? Any other tips? Thanks in advance.
-Noah
Offline lafindufondu
Re: ‘76 cb550f kick start wiring
« Reply #1 on: April 11, 2019, 01:45:56 PM »
Correct, you do not need the starter solenoid for kick only.
Offline Noah1981
« Reply #2 on: April 11, 2019, 01:57:31 PM »
Thanks. So just completely remove?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: April 11, 2019, 02:08:49 PM »
Yes, you can remove it if you want. Just make sure to properly route the connection from the alternator to the battery and the battery to the ignition switch
Offline Noah1981
« Reply #4 on: April 11, 2019, 02:14:17 PM »
Thanks! Could you expand on this process a bit? I’m using an m-unit and want to make sure I’m not making any mistakes..
Offline Noah1981
« Reply #5 on: April 12, 2019, 12:33:46 PM »
Try this- you can omit the parts and pieces you don’t want...
Also, there’s a forum section devoted to MotoGadget stuff  ;)
Thanks!
Offline Bankerdanny
« Reply #6 on: April 12, 2019, 01:49:25 PM »
Thanks!
Cal is the Motogadget guru and the moderator for that board, so he knows what he is talking about.
