Author Topic: Converting cb650 harness to a cb750 engine?  (Read 900 times)
Offline Choppedsohc
« on: May 09, 2019, 12:57:09 PM »
Anyone have experience doing this or could give me some guidance as to where to begin? Have a complete electrical and charging system for cb650 but a cb750 engine.
Re: Converting cb650 harness to a cb750 engine?
« Reply #1 on: May 09, 2019, 02:57:32 PM »
Charging system wont transfer and ignition system is totaly different
Offline Choppedsohc
« Reply #2 on: May 09, 2019, 09:49:32 PM »
Thank you, now to either buy a harness for the 750 or make one from scratch. Money vs time.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: May 10, 2019, 07:31:22 AM »
It is for a chopper? Do you need the complete OEM wiring or will an abbreviated version do? If you don't need a full harness I believe there is a DYI diagram available at the 750 Chopper site: http://www.hondachopper.com/garage/simple_wiring_diagram/simple_wiring_diagram.html
Offline Choppedsohc
« Reply #4 on: May 10, 2019, 09:46:21 AM »
I've downloaded that particular diagram and I need the complete electrical system for the 750 engine. I have a complete motor and harness including the charging system for the 650. I'm going to just have to bite the bullet and purchase a whole system and go from there.
Offline Bankerdanny
« Reply #6 on: May 10, 2019, 10:39:25 AM »
You only need a handful of stuff if your motor is complete. Not complicated.
« Reply #7 on: May 10, 2019, 03:55:38 PM »
Wires from motor
3 x charging
2 x field coil
2 x points
1 x neutral switch
1 x oil switch
Its that easy.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #8 on: May 10, 2019, 04:59:08 PM »
The honda chopper harness has everything but neutral amd oil switchs plus blinkers. If all you need is head light tail light amd charging + starting the honda chopper way is the way to go
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
