Author Topic: Crankcase Bolts  (Read 750 times)
Offline tacc13
Crankcase Bolts
« on: June 04, 2019, 03:01:35 AM »
I'm putting together an order for ARP 12pt bolts. The only lengths that ARP don't seem to do is the M6x32 flange bolts, which is understandable. I assume Honda would have used an M6x30 if that was suitable?
If so, are there any tricks to cutting down M6x40 bolts?
Thanks
Offline jlh3rd
  • "just who gets to determine my needs?
Re: Crankcase Bolts
« Reply #1 on: June 04, 2019, 03:10:24 AM »
thread a nut on the bolt first, cut the bolt, then unthread the nut to clean up the end.
or, use a universal thread restoration tool.
"alleged greed is usually a lazy person's opinion"
Re: Crankcase Bolts
« Reply #2 on: June 04, 2019, 10:36:53 AM »
Yamiya750.com sell with right marking on the head.
Offline tacc13
Re: Crankcase Bolts
« Reply #3 on: June 05, 2019, 02:19:13 AM »
Thanks all - Allens was my choice of supplier. Even with postage they work out significantly cheaper than buying them here. Will get the 6x35s!
