Before you get into the carbs swap the #1 and #4 plug leads. If the problem follows the wire it’s electrical. If it doesn’t, it’s time to clean those carbs. Just touch the pipes at startup, to see which are getting warm. No need to take it for a ride.
Well, I took your advice and swapped 1 and 4 and the issue didn't follow. so at least it's not electrical. What's interesting is that if I keep it at idle aka anything below 2k on tach. it shows a drastic difference in temp when compared to 2,3,4.
I should also mention that all 4 of my idle jet screws really don't do jack on changing the rpm's when I idle it around 1500k . Anyhow, I revved up the bike to about 5k (using the idle set screw)and took the temps. 1 started to get closer to 2,3,4. So if 2,3,4 were at about 250 degrees 1 would be at about 200-220 degrees. So it seems it balances out when the needle rises. Then for double fun, (because I'm probably going to be pulling the carbs to check the top end) I loosened the top set nut and turned the screw for the carb sync adjustment and it seemed to get better in temps. 1 was at 275 and 2,3,4 were at about 300 But even after all that overthinking basic troubleshooting, the bike still vibrates at about 4k and up on tach.
So maybe the vibration is something else. but now that I've messed with the screw and the other issues, I will probably pull them and then do a bench sync again and then vacuum sync once back on bike. Blaaa.
