SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
M-Unit and Electronics
Topic:
Combo rec/reg decreasing voltage?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Combo rec/reg decreasing voltage? (Read 2119 times)
greenjeans
Industrial strengthed dreamer.
Old Timer
1972 CB750K2
on:
September 20, 2019, 08:02:04 AM »
Could you lower the voltage coming out of a sealed combo rec/reg unit with a resistor or something before it hits the battery? I have one that charges at 14.7 volts. Using a new lithium battery that only wants to be charged at 14v. Possible? Or, is a new reg/rec in order?
Curious
Logged
RAFster122s
I feel like a really really
Really Old Timer ...
SOHC4 member # 2605
Re: Combo rec/reg decreasing voltage?
Reply #1 on:
September 20, 2019, 01:01:29 PM »
Resistor would have to be large power capacity to dissipate the power and it would get very hot. In another life I was a ceramic power resistor product engineer. Not practical as you would have to find a place to put it to prevent accidental burns and its performance is going to vary a little with extremes of ambient temp. The resistance value should not vary but it will see a swing in temp that varies with the heat of summer.
You would be better off buying the correct rect/reg unit than trying to jerry rig something.
Logged
scottly
Global Moderator
Humboldt, AZ
Reply #2 on:
September 22, 2019, 10:19:29 PM »
No, you can't simply add a resistor to change the regulated voltage. Rick's has a lithium specific regulator/rectifier, and Oregon Motor Parts has an adjustable solid state regulator.
Logged
greenjeans
Old Timer
1972 CB750K2
Reply #3 on:
September 23, 2019, 11:33:07 AM »
You guys guessed. We were hoping to reuse an old rec/reg combo I had for a buddy's bike. I'll relay the news. Thanks fellas
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Topic:
