Author Topic: Oil leak from head, part not on Diagram.....????  (Read 1551 times)
Offline 78cbfun
« on: October 22, 2019, 08:44:15 PM »
Guys I have a slight oil leak on my 78 cb 550. They look like press in metal dowels or plugs in the head. 3 on each side.  I have looked at parts diagrams but no info on what they are or if they can be replaced.  Temp sensor holes maybe?? Pic attached. Newb owner btw.  Thanks.
Re: Oil leak from head, part not on Diagram.....????
« Reply #1 on: October 22, 2019, 10:30:43 PM »
They aint replacable and only come with a head also never seen a leak there, common leak is O rings under the end cap held on with the crosshead screw and/or the soft washers supposed to be betwwn the steel bracket the screw goes into and rocker cover
Offline 78cbfun
« Reply #2 on: October 23, 2019, 03:19:11 AM »
Interesting....it does leaking from the press in metal piece.  But luckily ends caps on both ends are dry! Thanks for the information
Offline DaveBarbier
« Reply #3 on: October 23, 2019, 03:44:56 AM »
I have seen a couple posts of leaks from these plugs. And yeah, not sure how’d they be replaced but maybe by a machine shop. There shouldn’t be any pressure behind that so it’s possible that cleaning it as much as you can and a smear of Hondabond or something could help. Or you could find another head, they’re not that expensive on eBay used. A CB550 head from any year would fit.
Offline 78cbfun
« Reply #4 on: October 26, 2019, 07:54:02 AM »
I do work at a machine shop but don’t really want to start more problems by machining a new piece and maybe cause more leakage.  But I may take your advice and use extreme heat JB weld paste.
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #5 on: October 26, 2019, 04:37:17 PM »
Never seen them leak from the outside ones. I remove the centre ones on each side to clean the oil way out and machine up new ones, a little smear of Honda bond and press in.
Offline DaveBarbier
« Reply #6 on: October 26, 2019, 08:26:44 PM »
How do you remove them? I’d imagine drilling a hole, threading it and then using a bolt to pull it out.
Offline trigger
« Reply #7 on: October 26, 2019, 11:32:08 PM »
The outside ones can be pushed out if the head is off and the valves are out. Or you can drill in 3/4 of the depth of the slug, tap the hole and attach a slide hammer to the tap and pull it out. Measure up the old slug and make a new one on a lathe  ;)
Offline maxheadflow
« Reply #9 on: October 27, 2019, 08:00:47 PM »
How do you know what 3/4 the depth of the slug is?
