Author Topic: O rings for PD42A  (Read 611 times)
O rings for PD42A
« on: December 09, 2019, 03:23:33 AM »
What is the size of o-rings for what they call the joint set?  Is it the same like o-rings for the T at older carburetors?
Re: O rings for PD42A
« Reply #1 on: December 09, 2019, 05:48:12 AM »
Only way to know is strip a set and measure one as there is no part number or size mentioned in and Honda book i have seen
« Reply #2 on: December 09, 2019, 05:44:08 PM »
Measure the minor diameter of those grooves and subtract 0.1mm, then measure the ID of the carb's holes and add 0.1mm to that number. the thickness of these was either 1.6 or 1.9mm (I have seen both sizes), so to find the ID size:
(OD diameter - [2 x thickness]) will get you REAL close. Then the size is: (Thickness)mm by (Inner diameter)mm.
« Reply #3 on: December 10, 2019, 02:18:30 AM »
Thank you, Mark!
« Reply #4 on: December 10, 2019, 02:21:07 AM »
Btw the T joint from older carbs is bigger diameter than these.
« Reply #5 on: December 10, 2019, 06:43:50 PM »
Yeah, by quite a bit! The roundtop carb's tees are 1.9 x 7.9mm from Honda, but I use 2 x 8 instead so the ethanol 'wear' over time doesn't make them leak again. The ethanol makes them softer than pure gas did, so they develop a flat edge on the inner and outer surface which hardens when the carbs dry out. Then, they weep when fuel is added again, until the ethanol softens the rubber a bit (about 48 hours or so) and makes them stop it. We are seeing this happen with the rubber petcock valves in the pre-1976 bikes, too. So, I have taken [again] to storing mine "wet" over the winter, with the caveat that I might have a rocky restart next Spring, or might just suck the old gas out and into my JEEP, instead, for new gas then. I fill it all the way up, so as to minimize the surface area exposed to air (since the ethanol primes the open surface toward rust), and try to ride it once in a while on those nice days, filling it back up on the way home.
