Author Topic: Shortening forks CB550  (Read 2466 times)
Offline Ms Tokyo
« on: February 09, 2020, 08:41:32 AM »
I’m going the spacer and cut spring route. Question on the spacer. Would a copper spacer react and corrode in contact with steel or will the fork oil prevent that? I was going to use pvc but the outside diameter will not allow it to slide inside the fork tube.
Re: Shortening forks CB550
« Reply #1 on: February 09, 2020, 06:40:19 PM »
Why are you shortening the 550 forks?
Offline DaveBarbier
« Reply #2 on: February 10, 2020, 05:12:51 AM »
Copper won’t give any problems. My only concern would be that the side walls of copper tubing is generally pretty thin. So you should probably use washers on top and bottom of the tubing.
Offline WhyNot2
  • I'm finally an
« Reply #3 on: February 10, 2020, 10:48:42 AM »
Wondering too.
Why shorten.
Offline robvangulik
  • Honda Fourever
« Reply #4 on: February 10, 2020, 12:26:23 PM »
Must every pursuit be answered? "Why" is because he does. Does your answer depend upon him meeting your criteria? Either answer the question with technical information, or leave him to his decisions. It's his bike, not a committee-owned asset.
Maybe because what he wants to achieve could possibly also be done by other/simpler or better ways? If one knows what the goal is, one can think better about solutions.
Offline WhyNot2
  • I'm finally an
« Reply #5 on: February 10, 2020, 12:35:45 PM »
Oh, I'm not trying to discourage the op, just wondering.
Hoping they show what they are doing, always like to see others projects.
'specially since mine sit dormant.
Offline carnivorous chicken
« Reply #6 on: February 10, 2020, 12:37:28 PM »
...such as loosening up the triple tree and pushing the top of the forks through.
But I'm also curious as to why.
« Reply #7 on: February 10, 2020, 01:06:49 PM »
steepen the rake angle to make it turn faster?
« Reply #8 on: February 10, 2020, 03:03:04 PM »
Or Ms Tokyo is shorter than us...
« Reply #9 on: February 10, 2020, 04:59:51 PM »
Or put a spacer on the damper rod to shorten the assembly and reduce travel.
Offline Ms Tokyo
« Reply #10 on: February 11, 2020, 05:14:02 AM »
yes Honda man, I may be shorter than some others in the post, 5’6” to be exact. I was not shortening the forks for this reason but more so for appearance. I’m not sure this bike will even be ridden much. It’s more of a trial run and may become glorified garage art. It wasn’t in the best of shape when I found it. So back to the forks. I am not able to move the tubes up in the triple much without coming into contact with the handlebars. I planned to remove about 2” from the main spring and use a 2” spacer on the damper. Pretty common mod from what I’ve read.
« Reply #11 on: February 11, 2020, 07:00:07 PM »
The reason I ask: a man was killed on a bike from my shop when Suzuki didn't do the right thing with their swingarms on the early GT750. We had done all we should, but he got killed anyway, from a speed wobble that occurred from that issue (1973 model). Shortening front forks also shortens trail, which induces quicker steering and tendency toward speed wobbles above 45 MPH unless the rest of the chassis is rock-solid.
I've never forgotten that, and rebuild swingarms far better than new, at no profit to me, ever since. Just trying to help save a life here and there...
« Reply #13 on: February 12, 2020, 09:56:14 AM »
 Just a thought, check the fender to exhaust clearance. My brother lowered his 750 and it hit his header.
« Reply #14 on: February 12, 2020, 01:43:13 PM »
+1 i had a 500 with twin discs that would jam the fender between the two centre pipes and cause you to go straight on, scared the crap out of me and the IOM  police man stood on the corner on mad sunday, never knew they could jump that high or fast!! Admitedley found out about 6 monyhs later that the bottom tree had been knocked back on the stem(stem bent at bottom but not much)
Offline WhyNot2
  • I'm finally an
« Reply #15 on: February 12, 2020, 04:57:26 PM »
I'm just putting a set of CB550 forks on my CB750.......
And a CB550 swing arm.......should lower it just fine, I think.
