Author Topic: What Sprockets should I use?  (Read 933 times)
Offline Pkchevyguy
« on: June 09, 2020, 08:25:45 AM »
I have a 1975 CB750 four. I want to make my bike run a little lower rpm when out on the highway. I am running stick sprockets are this time. What would be a good sprocket combination to run for highway?
PK
Online bryanj
Re: What Sprockets should I use?
« Reply #1 on: June 09, 2020, 08:51:57 AM »
Stock is fine Hondas thrive on revs and economy will probably go worse if you change
« Reply #2 on: June 09, 2020, 10:33:11 AM »
So you have 18 front 48 back. Lot of bikes got changed to the lower 17 front. I run the stock 18. This is a K model 750 correct and not an F.
« Reply #3 on: June 09, 2020, 11:31:54 AM »
17:48 runs really well and match the engine and gearbox.
Going the other way on a stocker might force you to gear down all the time, maybe not possible to cruise on 5th gear against the wind.
17:48 revs just 250 rpm more at 60mph than 18:48
My K6 had 17:48 on long tourings in high speeds on Autobahn. Worked really fine.
I changed from 18:48 to 17: 48 a few days ago despite my engine has plenty of torque early, 1005cc.
I got thoughts about extra pain for trans and clutch when twisting from low so I changed back to 17 at front.
Bike felt much better direct!
My stock K2 runs also 17:48.
I knew some that used 45t rear back in the days.
Maybe with 17t front.
« Last Edit: June 09, 2020, 12:16:27 PM by PeWe »
« Reply #4 on: June 09, 2020, 02:03:05 PM »
 Never had a problem going against the wind or big hills in 5th with the 18, even with a passenger.
« Reply #5 on: June 09, 2020, 06:28:39 PM »
don't forget... rear tire overall actual diameter has a big effect on final drive ratios.  And don't get confused by tire sizes!  A 130/90/17 may be taller than a 4.00x18 depending  manufacturer.
« Reply #6 on: June 09, 2020, 07:32:34 PM »
Not making a recommendation, merely sharing what I use for interstate riding.....1976 CB750F
18/45 5:30 RK (Takasago) Gold chain. Rear tire 130/90-17
For in town Fun 17/48 RK (Takasago) Gold Chain. Rear tire 130/90-17
I've tired 16 front sprockets but never got any life out of them...Noisy real quick...
« Reply #7 on: June 09, 2020, 09:03:21 PM »
Not 18:48, if going 18:45 or more ;)
