Author Topic: Big intake heads from Cycle X  (Read 9649 times)
Offline dragracer
  • CB750F Dragbike
Re: Big intake heads from Cycle X
« Reply #50 on: January 08, 2021, 06:38:40 PM »
I think I'm going to contact Kenny soon to ask about the I.D. and O. D. of the spigots on his modified head. At this point, I don't feel I can break into the 9's without more airflow. I'm trying to avoid installing a stroker crank to achieve this goal.
How big is your motor now, Frank?
we q
It a 1030cc K headed engine with high compression pistons.
« Reply #51 on: January 08, 2021, 06:47:53 PM »
Yeah, some good head might put a smile on your face. ;)
Online Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #52 on: January 09, 2021, 05:43:37 AM »
Or several others, too
Offline dragracer
  • CB750F Dragbike
« Reply #53 on: January 09, 2021, 10:36:08 AM »
How many good heads are you storing under the bed Medyos. Lol
Offline dragracer
  • CB750F Dragbike
« Reply #54 on: January 10, 2021, 04:08:58 PM »
Looking for a 9 second pass and trying to eclipse 125mph.
« Reply #55 on: January 10, 2021, 09:48:32 PM »
How much work has been done on your K head, Frank? Have you had the bike on a dyno recently?
Offline dragracer
  • CB750F Dragbike
« Reply #56 on: January 10, 2021, 11:50:39 PM »
Head has been ported. New  33.5/28.5 SS valves with HD strings.  Rc 327 cam. Large intake boots with 34mm Mikuni flatslides.
Bikes not been dyno'd yet. I do plan to install a Wego so I can data log my AFR in real time. I  need to be certain my jetting is correct.
I can easily get this bike into the mid 9's if I decide to spray it. It just a major putting a fresh nitrous bottle in the bike and programming my nitrous tuneup.
« Reply #57 on: January 11, 2021, 12:43:51 AM »
Other cam that can improve?
Offline dragracer
  • CB750F Dragbike
« Reply #58 on: January 11, 2021, 10:19:36 PM »
PeWe. I haven't given much thought to a cam change because this is a drag only engine. The cam is for mid to high rpm range for larger cc motors. Lift and duration should be perfect for my setup.  I do have a larger RC 454 cam I could try but its doubtful I would gain anything with the size intake valve and ports I've got now.
« Reply #59 on: January 12, 2021, 12:43:07 AM »
Kenny Harmon Super F
Megacycle has alternatives too as CycleX has.
You or friends of yours might have tested before what these cams can do vs RC327?
Sam's Auto ran nice on the DP295 with good IN lift. ;)
