Author Topic: Mounting stud for side cover  (Read 984 times)
Offline Jimcg
« on: July 10, 2020, 10:27:23 AM »
I have no idea what's it called but does anyone know if the three studs on the side covers are some kind of standard stud that could be bought separately? They are a part of the plastic battery and air filter cover on my '82 CB650 and I want to make my own side covers but use the stock mounting brackets on the frame if possible.
Has anyone seen such a separate part, like a bolt with a similar cone shape at one end? Otherwise I'll figure something out, but it would make it easier if they already exist.
They can be seen in the corners of the side cover here:
https://images.cmsnl.com/img/partslists/honda-cb650-1982-c-canada-f-16-left-side-cover-rectifier_big3IMG01165923_5c18.gif
/Jim
1982 CB650Z RC03 owner in Eskilstuna, Sweden
About my bike:
http://forums.sohc4.net/index.php/topic,183848.0.html
Just the pictures and no text:
https://www.flickr.com/photos/189154615@N04/?
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
Re: Mounting stud for side cover
« Reply #1 on: July 10, 2020, 10:54:02 AM »
I think I've heard of someone using a bolt to replace a broken stud, but maybe something like this would work better for your purpose.
http://www.jwpartsplus.com/side-cover-repair-tabs.html
Offline Jimcg
« Reply #2 on: July 10, 2020, 11:48:45 AM »
I was hoping to find metal ones but that is absolutely best option so far. Thanks!
/Jim
About my bike:
« Reply #3 on: July 10, 2020, 11:53:30 AM »
 If you are using metal or carbon and don't mind the race bike look Dzus buttons could work. They are available in different head styles and sizes.
Offline Alan F.
« Reply #4 on: July 10, 2020, 12:04:59 PM »
When I was making aluminum side covers that bolted on, I used 'Well Nuts' that fit through the stock grommet tabs and bolted my covers on with socket head cap screws.
https://www.ebay.com/itm/M6-Rubber-Well-Nut-Universal-Windscreen-Fairing-6mm-1-2-Wellnut-1-Quantity/331334358727?hash=item4d251116c7:g:5RMAAOSwlupc~ouZ
Offline FourUsTry
  • Old enough to know better
« Reply #5 on: July 10, 2020, 02:20:54 PM »
I used one of those replacement plastic side cover studs and it worked well but you have to get the end in just the right position to work as original. I used modeling clay to see where it should end up and took pictures to use while cutting and JB welding it. It was fun for certain definitions of the word  ;) .
1978 CB550K
Past:
2001 VFR800
1980 CX500
Offline wolf550
« Reply #6 on: July 10, 2020, 03:27:28 PM »
hey jim check with godffery not sure if they are all the same but i bought some of those prong studs for some side covers I made for my 550. they are aluminum and they fit in the 3 rubber grommets that inside the metal tabs
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline Jimcg
« Reply #7 on: July 10, 2020, 10:08:09 PM »
 Many thanks, everyone!
I'm sure these suggestions will help me solve the mounting. I'm trying to solve every change I do to the bike with as little cutting as possible.
/Jim
« Last Edit: July 11, 2020, 02:01:03 AM by Jimcg »
About my bike:
