Author Topic: Front end swap  (Read 1004 times)
Offline The Duke
  • Pretty big nerd
Front end swap
« on: August 28, 2020, 04:33:43 PM »
Hey team.  I know there are lots of discussions on the forum about this, but no 2 cases are ever the exact same, so please indulge me and chime in if you can help.
I have a '74 CB750, and the fork tubes are just shot.  I have a line on some forks from an '82 DOHC CB750.  The tubes are still 35mm, so should fit in the stock clamps no problem, but is that a swap people have done?  I also want to upgrade to a dual disc on the front, so if I can find an '82 front wheel and calipers, then I figure I should be pretty well set.
Is anybody familiar with this idea?  Is my logic sound?
I am going to be replacing the master cylinder and lever with an aftermarket capable of pushing dual calipers, so that shouldn't be an issue.
I have attached a picture of the '82 forks.
Thanks in advance for any guidance.
I like motorcycles
I learn by doing
Offline The Duke
  • Pretty big nerd
Re: Front end swap
« Reply #1 on: August 28, 2020, 08:50:55 PM »
Update: I think these forks are actually off a CB750 Custom, according to Partzilla.
I like motorcycles
I learn by doing
Re: Front end swap
« Reply #2 on: August 28, 2020, 09:22:59 PM »
Those forks mount the axle in front of the center-line of the fork tubes, and will throw off the trail numbers if used with the stock triples. Look for '77/78 F-'79-81 750F, as these will slide right into the stock triples, and have the mounting lugs for the superior '82-up two piston calipers.
Offline TXRanger
Re: Front end swap
« Reply #3 on: August 30, 2020, 03:36:37 PM »
Another thing to find out is whether the fork leg spacing, center-to-center, is the same on both front ends. Even if the clamps are both 35mm, you could end up with wheel/axle/brake mounting issues if the widths are different. If the seller has the trees, maybe have him get this measurement before you commit.
1980 CB650 Scrambler project
Offline The Duke
  • Pretty big nerd
Re: Front end swap
« Reply #4 on: August 30, 2020, 04:01:15 PM »
Both good points.  I think I might have to wait for some good quality forks to come on the market, or go with new tubes.  I also like the original forks because I want to add a second disc up front, and that's gonna be easier with the original '74 forks.
Thanks dudes.
I like motorcycles
I learn by doing
Offline Bankerdanny
  • Endeavor to persevere
Re: Front end swap
« Reply #5 on: September 01, 2020, 11:38:25 AM »
Thanks dudes.
The easiest way by far to get dual disks is to fine a complete front end from a 77-78 750F and a pair of rotors from a 550. The only fab you need to do is to modify the speedo drive and shim the calipers to work with the wire wheel/rotor combo. I did it on my '76 750F in one day.
Offline The Duke
  • Pretty big nerd
Re: Front end swap
« Reply #6 on: September 01, 2020, 01:57:28 PM »
Thanks dudes.
That would be a good option, since I'm not going to be using the speedo drive anyway.
Thanks
Sent from my Pixel 4 using Tapatalk
I like motorcycles
I learn by doing
