Author Topic: Front Fork Interchangeability  (Read 2648 times)
Offline PoppaT
« on: August 31, 2020, 09:35:07 AM »
I'm sure this info is probably embedded in the thousands of pages of info provided by all you knowledgeable SOHC owners, so forgive me if this is easily findeable (but I couldnt quicly locate it)
My 1973 Honda CB 500 Four was "frankensteined" from multiple bikes by the prior owner.  My front forks are about 4 inches too long, sticking up nearly even with the top of the speedometer. ..and still I have to be on my tip-toes to reach the ground.  Other than that, the bike looks original.   I'd like to go back to the original fork length....whatever that is.   I see quite a few fork assemblies available on line, but dont see any for this specific year and model.   So my questions are:
-interchangeabliltiy of forks between years  72-74
-interchangeablilty of forks between bike sizes (cb 350, 450, 550, 750)
-Can I keep the existing lowers and only replace the upper tubes?   ...and if so, will I need different spring sizes, etc.
I'm not a mechanic, but am a relatively handy tinkerer.  So any other helpful advice would be appreciated.
Offline Pielz
Re: Front Fork Interchangeability
« Reply #1 on: August 31, 2020, 09:49:48 AM »
I'm 6 feet tall with a 34 inch inseam and I can't flat foot my k7 750 with the stock seat. I sit the same on it as I do on my 6'7" friend's Suzuki DRZ400. Lol
« Reply #2 on: August 31, 2020, 09:52:48 AM »
Are your triple trees correct for your bike ?
Offline PoppaT
« Reply #3 on: August 31, 2020, 12:35:26 PM »
good question.  I assume so. But not sure how to tell.   there arent a lot of 1973 models around to compare side by side.
« Reply #4 on: August 31, 2020, 12:41:26 PM »
Take a picture.
Offline PoppaT
« Reply #5 on: August 31, 2020, 03:25:03 PM »
Here's a few pics.  The fork length from axle center to top of the tube (not including the bolt on top) is 35.25 inches.
Offline Scott S
« Reply #6 on: September 01, 2020, 05:24:49 AM »
 Looks like someone "chopper-ized" the bike at some point and added extended forks.
 Any CB500/550 will fit. The CB750 is also 35mm but they're longer than the 500/550 forks.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #7 on: September 01, 2020, 08:07:47 AM »
750  is only like 3/4 inch longer, a bit stiffer spring I think.
« Reply #8 on: September 01, 2020, 01:26:43 PM »
There are internal differences 500 to 550 and by year but if you fit a PAIR of complete forks from one bike you will have no problem as long as you know what model and year for future parts supply
Offline jonda500
« Reply #9 on: September 01, 2020, 07:06:38 PM »
+1 any four cylinder CB 500 or 550 forks will fit
John
A starter clutch thread:
Offline PoppaT
« Reply #10 on: September 02, 2020, 04:25:30 AM »
Much thanks to all the knowledgeable responders.
John, Can I assume forks from a 350F or 450F will not fit?  (not sure about the tube diameter)
« Last Edit: September 11, 2020, 05:06:12 AM by PoppaT »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #11 on: September 03, 2020, 01:12:28 PM »
great looking Bike too bud!
That jade green is to die for!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline PoppaT
« Reply #12 on: September 03, 2020, 01:24:06 PM »
Thanks for the compliment.  I love the green also.  Here's a couple more pics so you can see what a beautiful bike she is for a 47yo that is regularly ridden.
« Last Edit: September 11, 2020, 05:00:08 AM by PoppaT »
Offline PoppaT
« Reply #13 on: September 21, 2020, 06:03:36 PM »
Can anyone provide me with the original CB500 full fork length (from center axle to top of the upper tube)?
