Author Topic: ultrasonic cleaner  (Read 2689 times)
Offline bear
  • Leeton in Australia
Re: ultrasonic cleaner
« Reply #25 on: October 18, 2020, 02:55:15 AM »
I have a 30L too. Complete carb rack, CB750 head no problem.
BUT, another smaller cleaner needed too for smaller things like one carb or the inner parts of all 4 or similar size.
Would you get a crank in it Per?
« Reply #26 on: October 18, 2020, 06:31:27 AM »
Had to check cleaner and a crank complete with alternator.
Without stud for advancer, yes.
Tank size: 500x300x200mm (L, w, h).
The version available today for same money, other seller. Mine has same data and look. A little bit cheaper today than soon 4 years ago.
 https://www.ebay.co.uk/itm/30L-Stainless-Ultrasonic-Cleaner-Ultra-Sonic-Bath-Cleaning-Timer-Tank-Heat/303724559580?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908103841%26meid%3D376c810512754663a5bb702328dd397a%26pid%3D100227%26rk%3D1%26rkt%3D14%26sd%3D303724559580%26itm%3D303724559580%26pmt%3D0%26noa%3D1%26pg%3D2053904&_trksid=p2053904.c100227.m3827
« Last Edit: October 18, 2020, 08:48:51 AM by PeWe »
« Reply #27 on: October 18, 2020, 08:46:09 AM »
Possible to clean sooty spark plugs in an Ultrasonic cleaner?
I have a bunch of sooty plugs, not much used.
2 or 3L version should fit that and other small parts, like wifey's jewelery.
« Last Edit: October 19, 2020, 08:20:09 AM by PeWe »
Offline spotty
« Reply #28 on: October 18, 2020, 07:07:25 PM »
if it was really hard baked carbon maybe not but little used ones would work you'd think
a friend of mine has an old workshop plug cleaner that was basically a mini sandblaster cabinet. its got a hole in the top to push the electrode end of the plug into , turn it on and it blasts with very fine media and hey presto clean plugs, the machine is probably 60 or more years old, from back when things got repaired and recycled
i blame Terry
Offline gpzkat
« Reply #29 on: October 18, 2020, 08:16:57 PM »
I was unsure of this site, but it turned out fine, 15L for $170 was the best deal I could find.  I put the cleaner in coffee tins most of the time.  It's a good sized unit.
https://www.kaiezen.com/products/ultrasonic-cleaner-duc-0015-00?_pos=3&_sid=74b7bf2d7&_ss=r
« Reply #30 on: October 19, 2020, 01:05:06 AM »
well mine turned up today,seems to be the type to buy,im still yet to try it out,looks good.
« Reply #31 on: October 19, 2020, 08:19:07 AM »
Thanks to this thread I might order a 3L version very soon!
I'll regret if not.
For bigger jobs I have the bubble bath, 30L version.
Might work as footbath with massage too? ;D
EDIT: Order done
https://www.ebay.co.uk/itm/224070784824
« Last Edit: October 19, 2020, 08:40:07 AM by PeWe »
« Reply #32 on: October 22, 2020, 01:35:25 AM »
ok ive got a lovely varnished up carby here to try,its off that sach bike of my mates im gonna get fired up we hope then piss it off (which means sell it here),i dont expect the machine to get all this off so a quick spray blast with cleaner,a quick tooth brush scrub and compressed air blow through and into the machine,ive let it go 30 minutes looks better and just doing another 30,im using hot tap water and a ph neutral truck wash we have here called ct18,i still like soaking brass in vinegar though,it comes out so clean.
« Last Edit: October 22, 2020, 01:40:43 AM by dave500 »
« Reply #33 on: October 22, 2020, 02:41:13 AM »
well im pretty well #$%*ing impressed!#$%* all elbow grease!the toothbrush scrub wasnt gonna get it any cleaner than it had!
« Reply #34 on: October 22, 2020, 05:19:27 AM »
I have just picked up my new 3L version. Quick shipping.
Lets see what I need to clean ;)
« Reply #35 on: October 22, 2020, 08:13:08 AM »
Those came up nice Dave. You are right to be impressed. They sure make cleaning tough stuff a lot easier.
« Reply #36 on: October 23, 2020, 01:55:56 AM »
yeah i think its still the norm to scrub off by hand the worst crud the best you can first,i never had one so clean so fast!
