Author Topic: when lacing wheels...  (Read 2708 times)
Offline Doobie
Re: when lacing wheels...
« Reply #25 on: November 20, 2020, 08:32:38 AM »
A cheap dial gauge like the one HF sells for $16 makes truing much easier than eyeballing it.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #26 on: November 20, 2020, 03:59:57 PM »
I find dial gauge gets in the way till you get it down to about 1mm or 1.25mm.... like 1/16 inch or better.
« Last Edit: November 20, 2020, 08:59:45 PM by 754 »
Offline XC204
« Reply #27 on: November 20, 2020, 05:28:00 PM »
A bicycle wheel trying stand works great if you can borrow one. Also follow the wheel lacing thread here I'll look it up.
http://forums.sohc4.net/index.php/topic,135846.0.html
Gary
« Last Edit: November 20, 2020, 05:30:40 PM by XC204 »
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #28 on: November 21, 2020, 05:49:29 AM »
finished lacing both wheels up but i'm going to drop them at the local shop to true and mount tubes and tires and balance.  came out great imo.  took the approach of taking one off at a time and taking off others that impeded the progress of changing the one i was focusing on.  at most i had maybe 5 off at a time.  generally it was 3 at a time.  definitely takes paying attention to where you are in the process.  cleaned and added anti-seize as i went.
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
« Reply #29 on: November 21, 2020, 05:54:00 AM »
slightly off topic but can i have the front rotor turned?  i noticed the "min 6 mm" stamp on the backside of the rotor.
cb750 k6 - ugly
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #30 on: November 21, 2020, 05:56:51 AM »
Yes, you cam
Offline evinrude7
  • not a kung-fu
« Reply #31 on: November 21, 2020, 06:02:53 AM »
Yes, you cam
thanks.
cb750 k6 - ugly
« Reply #32 on: November 21, 2020, 06:33:16 AM »
Usually ground... look for a place that does it often and is set up for it  Godfrey , I think is one of them..
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #33 on: November 21, 2020, 08:37:45 AM »
Godfrey or TruDisc (maybe spelled that wrong) Both are good.
They'll drill it too if you want, sheds a little weight and aids with water shedding, makes it look cool, which is very important. If it looks cool, it's faster and works better.
Magic
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline evinrude7
  • not a kung-fu
« Reply #34 on: November 21, 2020, 01:03:42 PM »
When you say grind how different of a process is that than turning and cutting on say one for a car disk?
Sent from my moto g(7) using Tapatalk
cb750 k6 - ugly
« Reply #35 on: November 21, 2020, 04:25:00 PM »
very different...requires totally different machinery.  Car discs are cast iron which can be cut on a lathe type machine.  Cb750 discs are stainless...much harder, too hard for a dedicated brake lathe.  I think some have managed it with special tooling but most will not want to risk ruining their tooling.  Thus it is a specialist grinding operation.  Fortunately, the stainless is so hard and thick, these disks are virtually indestructable.  I can't imagine one ever actually needing to be trued.  I had mine ground thinner and drilled to save weight.  The fresh ground surface does give better stopping power, but this will smooth out to the same old surface after 4 or 5 thousand miles.
« Reply #36 on: November 22, 2020, 11:44:38 AM »
Car hubs lend themselves to being machined, easier cutting better supported..
 Bike disc requires making adaptors , and very tricky to machine.  , very easy to screw them up..
 Grinding with disc removed can be fairly easy. . But different equipment..
 I spelt name wrong ..it's Godffrey I think..
Offline Alan F.
« Last Edit: November 22, 2020, 12:24:48 PM by Alan F. »
« Reply #38 on: November 22, 2020, 02:33:07 PM »
Yeah, thats the man
« Reply #39 on: November 22, 2020, 02:42:09 PM »
 Evinrude , you were sooo close to the finish line with your wheels....
 If you just want to spiff up the rotors spin them in a late and block sand it.. amazing.. but you have to cover the lathe ways and clean chuck real well..
Offline Alan F.
« Reply #40 on: November 22, 2020, 03:57:08 PM »
Will an orbital sander do?
« Reply #41 on: November 22, 2020, 04:14:54 PM »
It might be hard to keep off the carrier portion. .
Offline evinrude7
  • not a kung-fu
« Reply #42 on: November 24, 2020, 06:47:59 PM »
How important are these? Thought I read the sprocket cover could go but what about the nut savers?
cb750 k6 - ugly
« Reply #43 on: November 24, 2020, 07:42:56 PM »
Several alternatives...blue loctite, nyloc nuts, safety wire or buy new "nut savers" from honda
Offline evinrude7
  • not a kung-fu
« Reply #44 on: November 25, 2020, 06:39:57 AM »
Can I toss my chewed up sprocket cover?
cb750 k6 - ugly
Offline BenelliSEI
  • 1969 cb750
« Reply #45 on: November 25, 2020, 02:58:17 PM »
That “sprocket cover” always fascinated me. I suspect it’s purpose is the ensure a broken chain doesn’t get down and tangle on the axle? Anyone know?
PS. Toss it.
Offline evinrude7
  • not a kung-fu
« Reply #46 on: November 25, 2020, 05:00:26 PM »
PS. Toss it.
Thank you sir.
cb750 k6 - ugly
« Reply #47 on: November 25, 2020, 08:17:28 PM »
No , it there to help re and re the wheel if you have an endless  chain, or can't get master link off. ,
 Yeah you can leave it off. .
