Author Topic: o'rings for cam tower  (Read 1172 times)
Offline _mark
« on: January 07, 2021, 08:52:14 AM »
Hi guys.
I have found these orings that are going to fit at best the oil jet and the blind oil gallery on the cam tower (my engine is a K1).
These o'ring are 1,7 x 3,7 mm .
My doubt is in the blind seat; is a little bit larger than the oring, but the next step of the oring is complety out of the seat..
Are these oring good for their function ? thanks.
Re: o'rings for cam tower
« Reply #1 on: January 07, 2021, 08:55:35 AM »
Yes, the blind hole is only to blank off the extra oil feed in the tower that makes them fit either side so most oil goes to rockers and cam
Offline _mark
« Reply #2 on: January 07, 2021, 09:36:47 AM »
thanks for the answer. but maybe i wasn't clear in question. Is the oring fit for the blind passage or is too small ? the upper face of oring is slightly overlapping the flat plane of the head.
Offline Henning
« Reply #3 on: January 07, 2021, 10:10:52 AM »
The parts fiche calls for a 1.7 by 3.7 mm o-ring so you are good to go. No need to overthink it, it's just a blind hole that needs to be plugged. I have the top end off my K1 at the moment and have just ordered some of those.
71 or thereabouts 750 K1 - this one should have been put down
Offline _mark
« Reply #4 on: January 07, 2021, 11:50:38 AM »
thanks
« Reply #5 on: January 07, 2021, 12:33:10 PM »
It needs to overlap or it wont compress and seal
