Author Topic: 1978 CB550K4 Electrical Help  (Read 1562 times)
Offline mwah
« on: January 19, 2021, 04:48:10 PM »
I am rebuilding a 1978 CB550K4, however, I am currently stuck with an electrical issue.
Setup:
Stock reproduction handlebar switches from 4into1
Wiring harness from 4into1
Shorai battery
modern rec/reg
LED 2 prong flasher relay
Supernova LED brake/blinker/running lights from revival cycles
The issue I'm having is that I cannot get power to the running lights. Weird thing is that they will blink when the blinker switch is turned on. They will also light up when I turn the key to the "P" position. Fuses seem to be fine. Any idea why this is happening?
Any help would greatly be appreciated. Ive been stuck on this for the better half a week already. Thought it was the key switch but that doesn't seem to be the case (smashed the original one trying to open it up to see if any wires were not attached. Have since ordered and installed a replacement). What could it be?
« Last Edit: January 19, 2021, 05:17:07 PM by mwah »
Offline 69cb750
Re: 1978 CB550K4 Electrical Help
« Reply #1 on: January 19, 2021, 05:51:20 PM »
If you have double filament bulbs running light is brown/white wire.
Offline mwah
« Reply #2 on: January 19, 2021, 06:23:58 PM »
I do have a wiring diagram and have plugged the LEDs into the right wires, or so I think I have. The problem is that I get no voltage coming out of the brown/white wire. I only get that LED to flash when the blinker is turned on or the key is switched to "P".
« Reply #3 on: January 19, 2021, 06:42:10 PM »
This sounds a bit like a mis-conneciton in the headlight? But first - which 550 do you have? The early ones use the keyswitch under the gas tank, front of frame. The later ones use the key up by the instruments. These main harnesses are different, as are the keyswitch connections, and some imaginative wiring changes have to happen to mesh the 2 different types. The handlebars switches are a little different, too, which may be where the issue starts, here. The vendors often don't know the difference, with 4into1 being the least aware of which parts fits which bikes, in my experience with them. If it wasn't electrical, they can be good about exchanging stuff for the correct part when they mess up, though, so they aren't "bad" vendors, just confused sometimes.
The Running Lights and the Parking Lights are the same circuit, the Brown-White wire stuff. These are also on their own fuse in the fusebox.
The Turn Signals are powered via the Black wire system: it reaches the turn lamps via the flasher when the TRUN switch is in either position.
Offline mwah
« Reply #4 on: January 19, 2021, 06:48:33 PM »
My CB550 has the key in between the speedo and tach.
Im not sure if this helps but here are the links to the harness and switches I have.
Harness
https://4into1.com/main-wiring-harness-32100-404-670-honda-cb550k-1977-1978/
Switch
https://4into1.com/reproduction-left-switch-assembly-35200-404-671-honda-cb550-cb750/
Offline Bodi
« Reply #5 on: January 19, 2021, 06:50:39 PM »
I haven't checked the 550 wiring diagram but others have the park lighting - tail and headlight mini bulb (mini bulb not installed on USA models) - on a special wire connected (in the keyswitch) to the TAIL fuse in ON but switched to the MAIN fuse in P position. The markers are lit in P on a 550?
Offline Bodi
« Reply #6 on: January 20, 2021, 06:05:11 AM »
There are many dual contact LED bulbs to replace the 1157 type tail/stop bulbs. Some have two sets of LEDs and some change the power to get two brightnesses from a single LED or array. Very few are bright enough to be safe. The Osram ones are bright enough, some others as well.
« Reply #7 on: January 20, 2021, 06:37:51 AM »
Are you using these as tail lights, turn lights and brake lights? If so, the bike is wired for separate turn signals from the brake lights and these lights are wired for incorporated brake/turn system(like American early cars and trucks had) so you will need a 5 wire to 4 wire trailer converter to use just the 2 lights in the kit.
Supernova lights(notice he has separate turn lights)
Setup:
Shorai battery
modern rec/reg
