Author Topic: Rust Removal  (Read 1633 times)
Rust Removal
« on: March 15, 2021, 12:47:36 PM »
Posted this before and if you follow Terry P., this will be old news.....
Recently purchased a gallon of 75% Phosphoric Acid from a local farm supply (See photo). I’ve also found same stuff sold as “Stearns Milkstone Remover”. Used by dairy farmers to flush milking equipment after use, in very diluted form. As per Terry’s suggestion, I diluted it 10:1 with distilled water. Mixed a small batch to start, and had amazing results on the choke levers from my ‘69 cable carbs.
Yesterday, after I removed the exhaust spigots from the s/c engine, tossed one in. Again, amazing results. See photo, the back spigot is the “before”. Terry fills a large Rubbermaid tub with 10-12 gallons of the brew (1 gallon acid: 10-11 gallons water) and keeps it for long periods of time. Toss in anything that needs rust removal, leave overnight. Doesn’t seem to touch paint, or chrome. If the painted part has rust under the paint, beware, it will disappear! Just flushed out my gas tank with thinners, then acetone. Letting it dry and then plan to fill with this brew.
CAUTION. Pour the acid INTO the water, NOT the other way around. Apparently, after it looses effectiveness, you can toss the leftovers onto your lawn!
« Last Edit: March 15, 2021, 12:51:16 PM by BenelliSEI »
Re: Rust Removal
« Reply #1 on: March 15, 2021, 12:56:23 PM »
Good information!
The chemical names differs and more variants increase the chance to find here for affordable price.
I have found one variant very expensive. $12US/ liter.
Re: Rust Removal
« Reply #2 on: March 15, 2021, 01:48:27 PM »
Good information!
The stuff in the picture was about $30/ US gallon.
Re: Rust Removal
« Reply #3 on: March 15, 2021, 03:11:29 PM »
But what does it do to what is left of the original plating(other than chrome, like zinc and cadmium)?
Re: Rust Removal
« Reply #4 on: March 15, 2021, 03:18:13 PM »
Appears to leave chrome completely untouched.
Offline flybackwards
Re: Rust Removal
« Reply #5 on: March 15, 2021, 05:08:31 PM »
My experience is that it likes to eat cadmium and zinc plating - don't toss that on your lawn if it contains metals.
Re: Rust Removal
« Reply #6 on: March 15, 2021, 07:03:49 PM »
yep, so no more rusty hardware...for like one season if you are lucky.
Re: Rust Removal
« Reply #7 on: March 15, 2021, 08:41:15 PM »
I disagree. I cleaned up those spigots, gave them a bit of polish, and they look new. They might even last another 50 years.
Re: Rust Removal
« Reply #8 on: March 15, 2021, 09:27:20 PM »
If bike is parked inside when not used, the rust can not come back ;)
Re: Rust Removal
« Reply #9 on: March 15, 2021, 09:53:11 PM »
Did it clean out the carbon deposits inside the spigots?
Re: Rust Removal
« Reply #10 on: March 16, 2021, 01:43:14 AM »
Yes!  Works great for chrome parts.  I am talking about parts that are not chrome plated such as your choke linkage.  If the acid removes the little remaining plating, then those parts are gonna look worse than ever very soon.
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
Re: Rust Removal
« Reply #11 on: March 16, 2021, 05:20:02 AM »
PeWe, generally speaking that's true, but for humid climates like we have on the Gulf Coast we also have to worry about dewpoint. Because most garages aren't climate controlled, shiny bits will slowly corrode because of micro-condensation that forms on metal parts in the morning when they are still cool and the ambient air's dewpoint rises above their temperature. I had significant corrosion form on plated parts over the period of a few months. My solution was to run two dehumidifiers in my building. I have seen zero corrosion problems since I did that. Plus it's a lot more comfortable to work in there when it's hot.
Re: Rust Removal
« Reply #12 on: March 16, 2021, 05:36:44 AM »
OK, you have salt in air too spread by the winds...?
Air dehumidifier is not that cheap either.
Offline Maltboy
Re: Rust Removal
« Reply #13 on: March 16, 2021, 06:34:55 AM »
Not a lot of salt air since I'm about 20 miles inland, but the dehumidifiers aren't cheap (about $250 each) and they cost a buck or two a day to run during humid days. They don't normally have to run continuously, and some days when humidity is low they don't run at all. I figure it's worth it to keep my expensive toys from rusting and me from passing out.  :)
Re: Rust Removal
« Reply #14 on: March 16, 2021, 06:42:15 AM »
Softened it up enough I just wiped them out.....
Re: Rust Removal
« Reply #15 on: March 16, 2021, 08:45:50 AM »
Oxalic acid in powder form is a weaker acid and seems to be much safer for removing rust. You can buy 5 lb bag at Amazon for $19 US, or $27 for 10 pounds. There is one seller selling 40 pound pail for $125 but the only reviewer didn't like the lid seal being very tightly sealed and the material being clumped causing them to have pouring issues. Sounds like it was not really dry...but 5 gallon buckets can be a real pain to remove the lid, you do want it to seal well.
You mix it a pound to the gallon of water (distilled recommended) and it turns black as it removes the rust from parts. It chelates the rust just like Evaporust and Metal Rescue.
I think it is the same stuff.
Mix it in very warm water and it works faster... Leave parts in about 2-4 hours depending upon the amount of rust. It will not attack good metal and I don't think it affects zinc plated parts.
« Last Edit: March 16, 2021, 08:48:04 AM by RAF122S »
Re: Rust Removal
« Reply #16 on: March 16, 2021, 10:56:53 AM »
 Used to use that same acid in my woodwork refinishing biz back in the day for removing water stains from wood tops etc.. Its also considered a bleach.
Offline Freebirdbeachbum
  • I don’t want a pickle, ...
Re: Rust Removal
« Reply #17 on: March 16, 2021, 11:11:29 AM »
My plan has been to move to my house in Galveston on retirement but I know, from bitter experience, my vintage cars/MCs don't thrive in that corrosive environment even in my garage. I dont think all the dehumidifiers in the world would save them.
I could keep them in a climate-controlled facility on the mainland but that is so inconvenient I predict I wouldnt enjoy them as often as I would otherwise want to for my sake and need to for their sake.
Is there a bubble I could keep them in?
1972 Honda CB 750
1980 Honda CX500 Custom
1968 Wards Riverside Benelli 125
2017 Triumph Tiger Explorer XRT
2021 Lance Havana Classic 125
1965 Moto Guzzi Lodola Gran Turismo
Re: Rust Removal
« Reply #18 on: March 16, 2021, 12:25:28 PM »
ACF50 or similar coating on the bare metal pieces and keeping all painted areas waxed. I do mean all painted areas. ACF50 isn't recommended for paint but there are spray on coatings for motors that won't attack the paint but protect the metal and painted hot painted surfaces from rusting...cannot think of them at the moment.
Boeshield some guys use as well...
Offline Maltboy
Re: Rust Removal
« Reply #19 on: March 16, 2021, 12:27:11 PM »
Believe it or not, they make clear plastic bubbles for cars, but they use ambient air to keep them inflated, so they probably won't help with salt air. They're for dust mainly.  I live in Santa Fe which is about 20 minutes from the Galveston causeway.
Re: Rust Removal
« Reply #21 on: March 16, 2021, 01:14:30 PM »
Yes and a "car condom"!!
https://www.goodmans.net/i/9783/car-condom-disposable-plastic-car-cover-with.htm?sc=GOOGLEBASE&k=GC-85013&utm_source=GOOGLEBASE&utm_medium=datafeed&utm_term={QueryString}&gclid=Cj0KCQjwrsGCBhD1ARIsALILBYqjI4IInaNO9lR-XdCxxyHvolnXzLsRJHGqpHSEw8LER5aZHWwq9MUaAqByEALw_wcB
Drive safely, use a condom.
It might also be a problem with unwanted cars!!
Sealed "condom" around a bike will not let the humid air in. Rice in fabric bags inside absorb the initial moist.
Might work for longer storage.
