Author Topic: cam and rocker/follower interchangability  (Read 1689 times)
Offline timtune
« on: April 14, 2021, 11:12:42 AM »
I'm on a budget and hoping to buy as few new parts as possible.
I've got 6 motors I'm picking parts from to build one good one. Four 73Ks and 2 78Fs.
The cam from the F looks great and the lobe height and base circle specs are good based on my Clymer(Haines??) manual.
Can I use it in a K motor? The manual only has one set of specs for both F & K cam. With a second spec for automatics. Was the 78F cam different than a K cam?
Also can I mix and match cam follower (rocker arms) from K and F models?
Online Jerry Rxman Griffin aka MuthaF'er
Re: cam and rocker/follower interchangability
« Reply #1 on: April 14, 2021, 11:19:29 AM »
Yes and yes.
The F2/F3 cam was probably the hottest stock cam followed by the F0/F1 and K0/K1. Good choice. Use the valve springs from the F2 also. Stronger.
Offline timtune
« Reply #2 on: April 14, 2021, 11:30:30 AM »
So the head components (less the larger F valves) are compatible between the K and F? That would be great news.
Will the F3 ('78 F) cam make much of a noticable difference in performance when mated to a stock K motor?
« Reply #3 on: April 14, 2021, 01:38:03 PM »
Yes.
The increased performance will depend on which year K but should be an improvement especially between 73? and 76 K's which were detuned.
Offline timtune
« Reply #4 on: April 14, 2021, 03:03:26 PM »
I've come this far why stop now?
I have plastigaged one of the F motors and found the crank to be good. Is there any advantage to using that bottom end verus one of the Ks? (I know the final drive sticks out more- not a problem)
And a big Thanks for the quick response JRG!
« Reply #5 on: April 14, 2021, 04:51:01 PM »
I think you can use the F springs in the earlier heads, but not the top collar and keepers.
Online MRieck
« Reply #6 on: April 15, 2021, 06:42:22 AM »
Correct Frank....F2 springs work with early retainers
Offline timtune
« Reply #7 on: April 15, 2021, 07:08:07 AM »
And the bottom end is interchangable too?
I want to use the F final drive with the K transmission gear clusters.
« Reply #8 on: April 15, 2021, 08:55:57 AM »
I dont know if its the F final drive.., but since i put an F motor in my mileage , has been always bad.
 Are you ready for all the changes, should you put sn F motor in an earlier frame ?
Offline timtune
« Reply #9 on: April 15, 2021, 10:19:23 AM »
I've got a 76 F frame is that a problem?
Offline timtune
« Reply #10 on: April 15, 2021, 05:35:41 PM »
I was over this before as I now remember. 76F frame but with Comstars and triple discs. I seem to recall I made spacer to make the comstars to work. Been a long time.
« Reply #11 on: April 15, 2021, 06:09:23 PM »
 My F was happier with an 18 tooth front sprocket, the top two gears are lower if I remember correctly.  The F cam is a good choice, mine seemed torquey but I had too much fun revving it and tagged a valve using stock k springs.  The 78F front sprocket is 10mm further out, it can be used by matching the rear cush drive.
Offline timtune
« Reply #12 on: April 16, 2021, 06:48:25 AM »
Is that 10mm accounted for if you use the Comstars? I set mine up about 10yrs ago and can't remember
« Reply #13 on: April 16, 2021, 09:04:24 AM »
Ok , so frame does not affect it.
 If you have lomg shaft motor, rear sprcket must also move out , its all in the sprockrt carrier. What came with the Comstars or 77 and 78 K carriers and inner spacer is fine.
Lets assume you havr all that...
 Now the issue is which swingarm ? and your shock angle on chain side would be affected.
 Read the swingarm to axle size thread in this section.....
« Last Edit: April 16, 2021, 09:07:43 AM by 754 »
Offline timtune
« Reply #14 on: April 18, 2021, 07:06:06 AM »
Thanks Again! Will have a read.
