Author Topic: CB500 chain care  (Read 3825 times)
Offline flatlander
Re: CB500 chain care
« Reply #25 on: April 19, 2021, 01:48:22 AM »
I like the Swiss product Motorex Road Lube, one of you guys recommend it, used it yesterday on my Z1.
ha yes, that was me. and i'm still using it.
There ya go, thx FL
This one, right?
https://www.motorex.com/en-us/moto-line/chain-care/chainlube-road-strong/
I like it too as my chain...
yes that's the stuff.
« Reply #26 on: April 19, 2021, 01:49:01 AM »
Chain maintenance was much easier with old style of chain with a clip. Not riveted.
Lift bike so rear wheel can rotate, and use brush soaked in a good detergent while wheel is spinning.
Offline Bob3050
« Reply #27 on: April 19, 2021, 09:28:14 AM »
 With a little work to the front sprocket you are able to use an "O" ring chain. The front sprocket is wider through the center than it is at the teeth. If you machine one side flat and install the sprocket with the flat outward the retaining bolts will draw the sprocket away from the case enough for an "O" ring chain to fit. I average 10k to 14k miles on my CB500K2 with very little maintenance.
  Bob
Offline robvangulik
  • Honda Fourever
« Reply #28 on: April 19, 2021, 09:51:13 AM »
If you do that, I would advise to shim the rear sprocket outward the same amount to keep the chain in line, or the chain will wear faster. 10 to 14k miles with an o-ring chain isn't very good, I do a regular 25k miles with the x-ring on a 140hp bike!
