Author Topic: cb750k2 fuel tank badges plate  (Read 933 times)
Offline joseimport
  • 1972 cb750k2
« on: April 22, 2021, 10:09:15 AM »
hey guys... hopefully someone has a fix.
today i was riding my project bike and suddenly fuel was coming through the side of the tank.
the tank had been completely painted by some previous owner  and the dents for the emblems had been covered with paint, i did not know the condition of it below, as painting is the last thing i will do to this restoration.
the paint had bubbled up at that part, and i suspected there had to be a pinhole there, and today my suspicions where confirmed. the paint ruptured and fuel started dripping.
i removed the bubbled paint at that spot.
and the hole is right where the dents for the emblems are. this is fixable i just have to tig weld the tank.
but i noticed the plates where the emblems are held by the pins have been taken off. which is what created this problem to begin with.
what are my options here....  i want to restore the tank...  does anyone sell the plate so that i can have it re welded and be able to use the original emblems?
if this is not possible, maybe i can fabricate the plates and have them welded. i have not purchased the emblems and the little tabs that hold them in place as they are extremely expensive. i will have to get them so that i can fab the correct plates.
any suggestions of what i should do?
IMG_2790 by manuel caicedo, on Flickr
IMG_2789 by manuel caicedo, on Flickr
IMG_2788 by manuel caicedo, on Flickr
IMG_2792 by manuel caicedo, on Flickr
i will strip the whole tank and see how it looks
« Last Edit: April 22, 2021, 02:32:50 PM by joseimport »
1975 cb750k2: ongoing restoration project.
http://forums.sohc4.net/index.php/topic,183427.msg2122966.html#msg2122966
1979 rd400g daytona special: project in pieces.
1987 tr200 fatcat: running, future resto.
Re: cb750k2 fuel tank badges plate
« Reply #1 on: April 22, 2021, 11:49:35 AM »
Used replacement, should be lots out there or new yamiya painted one if you have the money
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #2 on: April 22, 2021, 12:06:09 PM »
3M makes emblem adhesive tape and it works great from my experience.
Offline joseimport
  • 1972 cb750k2
« Reply #3 on: April 22, 2021, 02:30:08 PM »
those are way to expensive....
i will strip this one tig weld the problem areas and see if i can restore it. hopefully behind all that plaster it looks better
Offline Alan F.
« Reply #4 on: April 22, 2021, 03:08:06 PM »
Be prepared for the rest to not look better though. Some tanks are horror shows under all the paint and filler. But you'll never know until you try.
Offline 69cb750
« Reply #5 on: April 22, 2021, 05:11:21 PM »
I made plates, pretty easy.
Offline Maltboy
« Reply #6 on: April 25, 2021, 06:30:13 AM »
The tank that came with my Basket Case was so bad underneath that I figured it was more trouble than it was worth to fix it.  Multiple bad welds, dents, and at least a dozen pinholes. I couldn't see the holes until I stuck a flashlight in the tank and turned out the lights.  White dots everywhere.  There was no way I was gonna spend a bunch of time and money to fix it and paint it just to discover it still had leaks.  I don't trust sealers, but maybe they're better than they used to be.  From my experience, they only lasted a few years and then began to de-laminate.  I was able to find a nice used leak-free tank, but it wasn't cheap.
« Reply #7 on: April 25, 2021, 09:29:40 AM »
 I had a similar tank, a PO had bondo'd over the tabs then tried to find the holes again with a drill bit. Then unexplicably finished it.   I tig brazed the hole, did the body work and repainted. I used 3m tape on the emblems.
