Author Topic: 1973 cb350f carburetor rebuild stuck needle valves  (Read 787 times)
Offline nor_al_67
« on: June 06, 2021, 11:55:46 AM »
Hi, I'm rebuilding my carbs and can't get the needle valves unstuck from the seats. These were really corroded and have been ultrasonic cleaned in berry-man carb cleaner. Is there a trick to getting them to slide out? The rebuild videos show these just slide out after disconnecting the pivot linkage.  Thanks,
Offline goodtryer
Re: 1973 cb350f carburetor rebuild stuck needle valves
« Reply #1 on: June 06, 2021, 11:58:55 AM »
I used several rounds of PB Blaster and a heat gun. Took 3 or 4 cycles but they came out nice and easy. Just be patient.
Good luck!
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline nor_al_67
« Reply #2 on: June 06, 2021, 12:03:43 PM »
Good luck!
Thanks, did you heat up the carb body where the main jet sits?
« Reply #3 on: June 06, 2021, 12:16:43 PM »
Do you mean you are trying to get the slides out of the bodies?
Offline nor_al_67
« Reply #4 on: June 06, 2021, 12:28:59 PM »
Yes, I assume the needle valve is stuck inside the seat which prevents the cylindrical slides from coming out.
Offline goodtryer
« Reply #5 on: June 06, 2021, 01:03:05 PM »
I heated the body. The vertical cylinder surrounding the slide you are trying to remove, where “Keihin” is embossed.
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
« Reply #6 on: June 06, 2021, 01:05:57 PM »
It is extremel unlikely the needle is stuck in the jet due to its shape, more likely the slide is stuck in the bodydure to carb cleaner
Offline nor_al_67
« Reply #7 on: June 06, 2021, 02:03:16 PM »
It was stuck before I used the carb cleaner.
Offline nor_al_67
« Reply #8 on: June 06, 2021, 02:30:40 PM »
I got one out by pulling and pushing the pivot and you're right, the cylinder was stuck in the "bore". But it was old the gas that had varnished it.  Thanks.
Offline Kevnz
« Reply #9 on: June 06, 2021, 02:40:18 PM »
I've found acetone useful in freeing these up.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
