Author Topic: removing factory paint from gas tank  (Read 24191 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: February 25, 2007, 03:23:42 PM »
Does anyone have some tips re: stripping factory paint off a gas tank? I have been using a citrus non-toxic paint stripper to pretty good success...at least on the top of the tank. The paint on the sides is proving more stubborn.
I have gotten the tank down to bare metal on the top.
Should I switch to a stronger stripper or should I be using a grinder at this point? I don't want to mar or scratch the metal surface.
1978 CB750K8; 1970 CB450
Offline 736cc
Re: removing factory paint from gas tank
« Reply #1 on: February 25, 2007, 03:28:37 PM »
Zip-strip works if you let it sit a while, agitate w/ some steel wool. If theres any bondo, a blow torch melts it out ez.
Offline eurban
« Reply #2 on: February 25, 2007, 03:31:32 PM »
Although it is nasty stuff, Aircraft Stripper (typical auto store will have it) will take off just about any paint.   Works much more quickly than the safe stuff but protect your skin, eyes and lungs.
Offline WJL75
« Reply #3 on: February 25, 2007, 03:56:33 PM »
Ditto on the Zip Strip.  I've used it a couple of times and it works quite well.
wjl75
1976 CB550K Cafe
Offline Blaize
  • Relax, God is make believe.
« Reply #4 on: February 25, 2007, 03:59:31 PM »
I did this last weekend and I also used zip strip. Juat like you It got the top just about bare but the sides not so much. I ended up using a scotch brite pad on a drill to do the sides. Worked great and damn near polished the metal underneath
Living the American dream (in England).
Offline xtalon
« Reply #5 on: February 25, 2007, 04:39:38 PM »
I used Strtoeeze by Savogran (Ace Hardware) and it worked pretty good.  I think it took 4 trys.  I put it on, let it sit for 20 minutes and then went at it with a metal scrapper.  I had to remove a paint job that was over the factory paint (including the factory stickers... yes, even the Wear a Helmet type sticker in front of the filler hole). :)
Once I got off what I could with the stripper, I wiped it down w/ paint thinner, let it dry and then sanded w/ 150 and 100 grit sandpaper and also used a stainless steel brush.
Did a little more sanding w/ some 220 I think.  I also used a stainless steel wire wheel on my drill to remove a couple places that were trying to rust. Not saying this is the best way, but it worked for me.
Oh yeah, I also removed the spraybomb paint job off of the GL1000 forks, hence why it's included in the picture.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
« Reply #6 on: February 25, 2007, 04:55:59 PM »
You can increase the effectiveness of any stripper by covering the part tightly in plastic sheet or tin foil overnight. I learned this from custom painters. It keeps the volatiles from out gassing and allows them to work on the paint longer.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: February 25, 2007, 05:53:27 PM »
I'll second the aircraft stripper.  Used it to strip my 550 tank and the paint was falling off after about 30 seconds.
masonryman
« Reply #8 on: February 25, 2007, 06:06:46 PM »
the aircraft stripper is some good stuff and if you do get it on you cold water neutralizes it very quickly.
As for the torch to the bondo I would stick to the grinder for that, heat on sheet metal is a bad idea unless you are looking to take up body work, the heat will warp and swell the sheet metal.
Mark
Offline jabbadeznuts
« Reply #9 on: February 25, 2007, 06:25:44 PM »
Aircraft stripper
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: February 25, 2007, 06:30:14 PM »
Aircraft stripper
Sorry Jabba, but that's not a special kind of stewardess you get in first class. ;)
Offline Patrick
« Reply #11 on: February 25, 2007, 06:35:33 PM »
I use Aircraft sripper. It works very weel. The paint cmes off i sheets. It's also great for taking off old powdercoat. After an application of Aircraft stripper, powdercoat will come off with a toothbrush.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
wesniles
« Reply #12 on: February 25, 2007, 06:40:43 PM »
AIRCRAFT STRIPPER!
i worked  in a shop restoring classic cars and all we ever used was aircraft stripper. its really nasty if u get it on your skin and eats right thru latex gloves, so if u do use it put on a couple pairs of the blue butyl gloves.  it does take off any thing you can throw at it, even light coats of bondo and glass fillers.
drlarryw
« Reply #13 on: February 25, 2007, 06:48:18 PM »
For a non-chemical alternative.....I've used a round, medium grit sanding disk with my electric drill and in less than an hour had stripped original Honda paint and clearcoat off a Nighthawk tank.  Then fine sanding, cleaning and the tank was shiny aluminum, ready for priming.  What did I miss my not using chemical strippers?
Larry in Boston
[the same guy who uses molasses to clean rust out of gas tanks.]
Offline Pwfyrcat1
  • What I'm doing when it's warm
« Reply #14 on: February 25, 2007, 07:10:15 PM »
Aircraft Stripper
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: February 25, 2007, 07:11:33 PM »
Larry in Boston
Who said you were missing anything?  Different methods, same results.
Loas 78 CB750K
« Reply #16 on: February 25, 2007, 09:57:50 PM »
Larry in Boston
How does the molasses thing work?
Zane
« Reply #17 on: February 25, 2007, 10:44:35 PM »
Someone posted this before - I found it interesting.
http://www.chuckhawks.com/harley_prep.htm
« Last Edit: February 25, 2007, 10:50:04 PM by Zane »
Offline hymodyne
« Reply #18 on: February 26, 2007, 04:18:01 AM »
aircraft stripper, or gasket remover.
I just took most of my frame down to bare metal with one can, removing about four layers of paint. I bought a 750 tank for my cafe project and striped it with aircraft stuff as well,then hit it with a jitterbug and some 100, then 220 grit paper, shot it with three coats of green death.
Hym
Offline Pwfyrcat1
« Reply #19 on: February 26, 2007, 12:39:22 PM »
hymodyne,
what is 'green death'?
1992 Yamaha TDM 850
« Reply #20 on: February 26, 2007, 02:34:55 PM »
Aircraft stripper
Only in my dreams do I get an aircraft stripper.
'75 CB550
« Reply #21 on: February 26, 2007, 05:06:02 PM »
Larry in Boston
Larry, It turns out Molasses binds with rust on a molecular level through chelation. Acids dissolve the rust and of course the metal around it. It is safe and cheap and worth a try.
Offline Steve F
« Reply #22 on: February 26, 2007, 05:45:36 PM »
I glass bead blasted mine.  20 minutes in the cabinet, and everything, including some bad bondo job was all gone.  The p.o. tried to bondo over the badge mounting bracket and the depression, and the bead blasting was able to remove the bondo from under the bracket.  After a littile dolly work and some thin coats of bondo here and there, it was ready for paint.  Mind you, I'm not the guy doing the body work, I just watched the pro.
Offline hymodyne
« Reply #23 on: February 27, 2007, 04:44:48 AM »
"green Death" is how I have heard folks in the paint business refer to self etching primer.
I've got bondo and three coats of self etching on the bare tank, followed by two coats of sandable enamel primer.
going to sandblast the chemically stripped frame. By the way, I chose to try zip strip to keep my travel time down for stripping agent yesterday. It worked very well on tough places on the frame that the aircraft stuff had missed. I used a stiff narrow wire brush with stiff bristles to remove everything I didn't scrape off with a putty knife.
hym
Offline GNXFan
« Reply #24 on: February 27, 2007, 06:29:29 AM »
I use my 5 gallon can of Berryman Chem Dip Professional Parts Cleaner, a.k.a. carb cleaner to not only clean carb parts but to strip paint almost instantly. It just melts any type of paint down to the bare metal. No sanding required. Obviously a tank or frame won't fit into the can but I just pour it into other pans, etc. until  they they can be submerged into the cleaner. This stuff costs about $75 at O'Reilly's Autp Parts Store.
I'll post some example pics later.
