Author Topic: 022A choke lever and flap question  (Read 1284 times)
Offline gbal06
« on: July 02, 2021, 02:28:11 PM »
So I rebuilt my carbs and notice that when I adjust the choke it doesn't stay open and "springs" back to approximately 1/4 open. I adjusted the the flap adjusters which does improve the spring back but does not keep the flaps aligned.  For some reason I am brain farting on this, but I do not remember the choke lever "snapping" back and that I could adjust the choke lever to what ever position I wanted.  Any ideas?
Offline Kevnz
Re: 022A choke lever and flap question
« Reply #1 on: July 02, 2021, 03:33:19 PM »
Did you have the carbs separated? Looks like each choke butterfly has its own spring which tries to close the choke, but the left carb with the choke lever has a little plate on the opposite side of the lever which has an indent and a spring loaded little ball bearing that applies pressure on the plate to hold it in any position. Lost that ball and spring, perhaps?
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline Kevnz
« Reply #2 on: July 02, 2021, 04:01:02 PM »
Pic showing right side of left carb. See the little ball bearing? It seats into a hole in the plate in the choke open position, and applies pressure to the plate in any other position to keep the butterflies at that place.
Offline gbal06
« Reply #3 on: July 02, 2021, 04:34:50 PM »
I did have them separated and clean, but I don't remember ever seeing a spring or ball bearing on there. It could be a possibility that I did lose it, but didn't take the choke level apart. Do you have a pic of the ball and spring
Offline gbal06
« Reply #4 on: July 02, 2021, 04:41:53 PM »
is this the ball bearing you are referring to?
Offline gbal06
« Reply #5 on: July 02, 2021, 04:42:36 PM »
Here is the choke in action and a picture of the right side of the #1 carb
Offline gbal06
« Reply #6 on: July 02, 2021, 05:07:54 PM »
looks like the ball bearing is there but I don't know if the spring behind the bearing isn't strong enough, the plate that the bearing engages into is bent or if I need to tighten the nut down on the plate that the bearing engages into.
Offline Kevnz
« Reply #7 on: July 02, 2021, 06:12:37 PM »
Yeah, that's the right area. Hard to tell from the pic whether there's a spring behind the ball applying pressure or not. Try pressing it in with a small screwdriver and see if there's any tension. Either way, I suspect that's where you need to be looking. Carb bits appear to have been painted; any chance paint is gumming something up?
Offline gbal06
« Reply #8 on: July 03, 2021, 09:56:55 AM »
 I think the pain may have gummed up the hole of the plate so the ball doesn't fully engage into the plate.  I am going to try and clean the hole a bit with out taking it apart.  If anyone has any good ideas please let me know!
Offline Kevnz
« Reply #9 on: July 03, 2021, 02:25:27 PM »
Should be able to do it with a drill bit. Just close the choke a bit to expose the hole. BTW, you can check whether the spring is applying pressure by poking a small jeweller's screwdriver through the hole with the choke in the open position. That will tell whether that's your issue.
Offline gbal06
« Reply #10 on: July 04, 2021, 08:12:55 AM »
LOl that is exactly what I was planning to do tomorrow.  Does the ball spring usually go bad?
Offline gbal06
« Reply #11 on: July 05, 2021, 01:37:01 PM »
As ashamed as I am the only thing that needed to be done was to tighten the nut that was holding the plate on.  :( well now I know
Offline Kevnz
« Reply #12 on: July 05, 2021, 01:54:30 PM »
At least you fixed it and manned up, to boot. Good stuff! Cheap fix too. ;)
Offline gbal06
« Reply #13 on: July 05, 2021, 02:10:18 PM »
True. And I am glad it wasn’t anything worse
