Author Topic: Fuses?  (Read 1278 times)
Offline disco
Fuses?
« on: September 30, 2021, 03:22:54 AM »
Where do you all buy your fuses from? They measure about 1” x 1/4”. I’m finding it really difficult to buy the correct size. As it stands I now have a #$%* ton of 1 1/4” x 1/4” fuses as well as M205 fuses (20mm x 5mm). Neither of which fit real well.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Re: Fuses?
« Reply #2 on: September 30, 2021, 05:31:04 AM »
Or, replace your fusebox with an ATC fusebox. HondaMan sells one, or you can build your own...
Re: Fuses?
« Reply #3 on: September 30, 2021, 08:24:07 AM »
I found some 5x25mm glass fuses on Ebay, Germany some years ago.
I ordered some 5 packs of 7A, 15A. Maybe 10A too.
5A not available then.
Good to keep stock fuse boxes when they work.
Both my bikes have relays fed by thicker wires direct from battery with hanging 10A mini fuses to make life easier for ign switch and bar switches. Hi, Lo, ignition.
