Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Just to confirm it doesnt happen immediately and engine has to run for a while for it to happen?
Stupid suggestion. Use two crush washers.
Is the motor very noisy (clanking) when running?If it is. Sounds like a connecting rod bearing is bad.Did you do an oil change? maybe lots of metal in the oil?
