Logo merchandise is available at the SOHC/4 Shop
Just to confirm it doesnt happen immediately and engine has to run for a while for it to happen?
Stupid suggestion. Use two crush washers.
Is the motor very noisy (clanking) when running?If it is. Sounds like a connecting rod bearing is bad.Did you do an oil change? maybe lots of metal in the oil?
