Author Topic: Clymers High Performance modifications  (Read 3391 times)
Offline timtune
« on: December 01, 2021, 09:42:54 AM »
Anyone have a copy of this manual? I'm missing the back pages and I'm curious about the hipo mods for "track, sport, touring"
Re: Clymers High Performance modifications
« Reply #1 on: December 01, 2021, 12:18:35 PM »
Pretty sure I do. Will have a look.
Offline timtune
« Reply #2 on: December 01, 2021, 06:30:07 PM »
Thanks. Got the book decades ago with a basket case. Been curious ever since.
Offline 1080
« Reply #3 on: December 01, 2021, 07:18:28 PM »
My copy starts with Chapter Twelve Performance Improvement page 191-212. Page 213 has a list Manufactures & Services.  Index starts on page 214-216, and then there is 8 pages of colored electrical diagrams K1,K2,K3-K7, K8, CB750F 1977, CB750F 1978, CB 750A,and lastly CB750 U.K. Lots of scanning.
Offline timtune
« Reply #4 on: December 02, 2021, 07:04:01 AM »
I have a later printing which is the same for most of the book. So I have all the wiring diagrams and such. I'm just missing the performance mods.
Don't need them scanned, even a breif outline would be good.
Offline dragracer
  • CB750F Dragbike
« Reply #5 on: December 02, 2021, 01:03:23 PM »
I have one at the shop. I'm fairly certain it's complete.  Will check for you a little later.
« Reply #6 on: December 02, 2021, 04:08:12 PM »
 I forgot to look, mine would be easy to scan since the binding is gone and it's a stack of pages.
Offline timtune
« Reply #7 on: December 02, 2021, 04:27:50 PM »
Look close. You can see the bulldog clip holding mine together.
Offline dragracer
  • CB750F Dragbike
« Reply #8 on: December 02, 2021, 09:01:36 PM »
Apparently mime doesn't have a section with performance mods included.  Hopefully someone else can help you out.
Offline CycleRanger
  • No comment about being an
« Reply #9 on: December 02, 2021, 09:26:04 PM »
Apparently mine doesn't have a section with performance mods included.  Hopefully someone else can help you out.
Yeah, I checked my copy and it's the same, no mention of performance mods.
They must have dropped that from the later editions.
« Reply #10 on: December 03, 2021, 09:07:14 AM »
Mine is apparently a 1976 edition with no performance section.
« Reply #11 on: December 03, 2021, 09:43:15 AM »
Suspension: rear shocks, swing arm bushings, aftermarket swing arms, front forks, fork springs, fork damping assembly, fork replacement, wheels (Morris Lester Comstar), brakes, tires, kit bike (Rickman).
Engine: exhaust, air cleaner, ignition, oil cooler, engine stages, camshaft, big bore kit, lightened alternator, connecting rods, balancing, cam chain, carburetor, clutch, transmission, cylinder head.
« Reply #12 on: December 04, 2021, 01:08:11 AM »
Search the forum here for modifications. There are many live examples about smaller and bigger mods.
A stock CB750 can become more fun with a little bit more compression and exhaust that breath, not HM341 4-4.  Yamiya No Numbers 4-4 or HM300 4-4 or a 4-1/4-2-1 yes.
My CB750 K2 got that.
Good head with fresh guides/valves + fresh bore/pistons are essential, modified or stock.
Terry in Australia has a K0 he gave higher compression pistons that runs fine.
My K6 got the full package $$$$$!
Finding a newer but used bike with more power from the very beginning should have cost me around half of the go fast parts with reinforcements. ;D
But I married that bike early 1979 and cannot say no when she begs for more over and over again!! ;D
Hondaman's (Mark Paris) book has also descriptions of modifications to do and how.
Over 836cc /+8000rpm the package will need more money with better rods. That was written in an old magazine where Mr Yoshimura talked about tuning a CB750. That is attached deeper down in this forum.
These engines are very old now, update of the primary drives cush rubbers can be a good idea. Not on my list 35-40 years ago. ;D
Holy crap what time goes by!!!
Offline Alan F.
« Reply #13 on: December 04, 2021, 06:29:56 AM »
Mine is a later printing too, sorry.
« Reply #14 on: December 04, 2021, 08:35:22 AM »
I have that section in my old Clymers
« Reply #15 on: December 04, 2021, 03:41:57 PM »
I found my Clymers and began to scan it before I noticed it's a gl1000 book. Fooey. Mostly about parts you can't buy anymore. My Chiltons is a 750 book and also a stack of pages. Looks like it was stored in an oily towel or a coal mine and no performance section either.
 The book with the performance section has a banner across the top referring to RC engineering and a logo in the top right corner that says color wiring diagrams.
« Last Edit: December 04, 2021, 03:58:05 PM by Don R »
Offline commander60
« Reply #16 on: December 04, 2021, 05:38:45 PM »
I have a Clymer with hipo mods in it, really cool, let me know if i can help.
Offline timtune
« Reply #17 on: December 04, 2021, 06:01:29 PM »
Can you briefly tell us some of the suggested mods?
Offline commander60
« Reply #18 on: December 04, 2021, 06:41:29 PM »
Rear shocks, swing arm bushings, fork springs, heaver oil, lighter wheels, brakes, double disc's tires,
Engine, carbs, cam, exhaust, larger bore, air cleaner, high output ignition.
It talks about stage one, two, and three engines
There are a couple of cool pictures, like RC engineering bike with some Weber's and a Cobra engine.
If it is aloud, I can scan the whole section.
« Reply #19 on: December 05, 2021, 11:21:19 AM »
Another good read for CB750 owners with upgrade thoughts.
http://forums.sohc4.net/index.php/topic,38253.msg393997.html#msg393997
Found the Yoshi article. I attached it a few years ago;)
http://forums.sohc4.net/index.php/topic,147470.msg1679064.html#msg1679064
Russ Collins Cobra engine build article.
http://forums.sohc4.net/index.php/topic,176295.msg2050421.html#msg2050421
Lets hope you'll get the Clymers tuning pages too. ;D
« Last Edit: December 05, 2021, 11:29:12 AM by PeWe »
Offline mick7504
« Reply #20 on: December 05, 2021, 11:51:01 PM »
Hoping that this helps out.
These pages haven't seen the light of day for a very long time.
If I was you
I'd be worried about me.
Offline johno
« Reply #21 on: December 06, 2021, 12:33:34 AM »
Ahh Mick, they were the good ol days mate, every word written about hi po 750 Honda was like reading a bible. I reckon I spent more on magazines than on my bike.  Thanks for the post.
cheers Johno
Offline mick7504
« Reply #22 on: December 06, 2021, 01:02:30 AM »
cheers Johno
How are you going Johno
Yes they were good days mate and a lot of fond memories taking down to the wire and a bit beyond and we got away with it.
If I was you
« Reply #23 on: December 06, 2021, 07:03:02 AM »
Fun info.
This together with Action Fours and Russ Collins catalogs nice reading before Christmas whenever it was supposed to happen. Just order when you want it to happen;D
I'm really pleased that the go fast parts got a comeback 35 years after bike stopped to be made thanks to CycleX, Dynoman, APE, Webcam, Megacycle, Mike Rieck and others.
Parts better than ever.
I synched my carbs today and got it to idle really nice. Like a nice stocker with a little bit harder sound, absolutely not as 125-75 cam numbers can be thought to act.
I need to find one more. It would be horrible if not having a spare before production is stopped.
« Last Edit: December 06, 2021, 07:06:04 AM by PeWe »
« Reply #24 on: December 06, 2021, 07:39:46 AM »
Fun info.
I can get you a 125-70 cam anytime you want Per.....they are all hardwelded now so all you need is a donor cam and i have a number of them on hand.
