Author Topic: CB550 Help! (Electronic Ignition/timing)  (Read 1021 times)
Offline Jcop.550
« on: December 31, 2021, 03:09:58 PM »
Looking for help on my 78 CB550. Just rebuilt the engine and rewired the whole bike from scratch for the first time and everything is working as it should.
I also installed a PAMCO electronic ignition. The bike is getting good spark and fuel but it does not want to start. With the electronic ignition, should I be able to install it and start the bike and then set timing afterwards? Or set the timing before? When trying to start it occasionally makes a “whomp” and backfire sound.
Trying to weigh out my options to get to the bottom of this. Any help or advice is appreciated
Re: CB550 Help! (Electronic Ignition/timing)
« Reply #1 on: December 31, 2021, 03:12:36 PM »
You have toget the timing close for it to start. Never seen a pamco so not sure what you change and how it works but setup should be in the instructions
Offline Jcop.550
« Reply #2 on: December 31, 2021, 04:30:12 PM »
I did that before giving it a try. I’m gonna double check and make sure I’m doing it correctly. Hopefully it’s something silly I messed up on
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: December 31, 2021, 09:59:29 PM »
Sure you got the coil leads headed to the right pair?
iirc, the pamco plate and advancer are marked.  So you can get things set up at tdc within a degree or two of fire.  The timing light helps to verify the advancer mechanism works above 3000rpm.
« Reply #4 on: January 01, 2022, 12:40:58 AM »
Rotor correctly mounted, not 180* wrong?
If it is, swap the wires to coils and see if it starts.
