Author Topic: How can I test electricals without a battery?  (Read 3209 times)
Offline kurtkarram
« on: January 08, 2022, 08:45:46 AM »
I have a 73 cb500 just bought with a dead battery. I'm waiting for the new battery to come in. Is there any way to test the electronics without a battery? Can I hook up my battery charger directly to the terminals to run current through the system and test the lights?
Re: How can I test electricals without a battery?
« Reply #1 on: January 08, 2022, 10:31:28 AM »
Jumper cables from car battery will work.
Offline dusterdude
« Reply #2 on: January 08, 2022, 12:28:45 PM »
Or buy a power probe III
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #3 on: January 08, 2022, 12:29:37 PM »
But you'll still need a battery to connect it to.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Alan F.
« Reply #4 on: January 08, 2022, 12:44:04 PM »
If the car battery is still attached to a car....do not start the car's engine with the battery jumpered to your bike.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #5 on: January 08, 2022, 10:30:38 PM »
I may have been guilty of burning up some starter brushes this way when i started messing with bikes....
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Alan F.
« Reply #6 on: January 09, 2022, 11:36:46 AM »
Hogwash. As long as you don’t cross the polarity, it’s perfectly fine.
Really? No burned up rectifier or regulator from too much available current?
Edit: I agree with not crossing polarity.
« Last Edit: January 09, 2022, 11:38:29 AM by Alan F. »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #7 on: January 10, 2022, 03:02:37 PM »
Really. The bike will only draw what it needs. The cars alternator is likely already limiting output to 14.4v.
Elextronics I'll be fine as they one draw what they need. When you keep cranking that starter like any electric motor they will draw more amps with higher temps.
Just had to replace a motor at work in a hoist cabinet over the same thing.
