Author Topic: CR Carb Float needle broken how to fix  (Read 4326 times)
Offline RickP
« on: June 30, 2022, 05:56:26 PM »
Hello All,
Been long time that i've been on this forum, but i need help
 i got a CR 31 Carb for my CB900F 1982, only one issue is one of the support for the needle to hold the float is broken, any idea on what product to glue/sod this piece in order to keep the float in place..
see photo attached
Re: CR Carb Float needle broken how to fix
« Reply #1 on: July 01, 2022, 10:55:05 AM »
Send it to member Jim French, Atlanta area, for micro-welding
« Reply #2 on: July 01, 2022, 09:51:10 PM »
That would be member Jim F: http://forums.sohc4.net/index.php?action=profile;u=4044
Since you only have 1 post, you can't send him a PM; you need 5 posts. BTW, what part of "NOT for Questions" is it that people don't understand? ::) ::)
« Reply #3 on: April 05, 2025, 02:30:36 PM »
 I have tapped a cut-down, notched and drilled brass bullet casing over the remaining post. I also used some gas tank repair epoxy to glue it into place.
« Reply #4 on: April 05, 2025, 07:22:53 PM »
Was that a .22 case?
« Reply #5 on: April 05, 2025, 08:22:32 PM »
It was some empty centerfire wildcat bullet case that my brother had in his snap-on box that we share here. He doesn't really know what it was, and I threw away the case end after I cut it. It did have a small neck down on it though.
How bullets end up in a mechanics toolbox I'm not sure, at least that one was expended.
« Reply #6 on: April 10, 2025, 11:08:15 AM »
 I haven't used this one yet but I used a piece of 1/4" soft copper tubing to repair a rotted float post.
Offline CycleRanger
  • No comment about being an
