The f2 gear set comes with the wider output shaft but can be swapped to the older one. On a street/highway bike I like the F ratio with a taller sprocket.
My old K0 was revving 5200 on the highway yesterday, the cam was loving it.
I have an ongoing engine build that has a later transmission.
It looked so good and not much used so I had to buy it. Complete crank with rods and alternator + starter gear from same engine.
The last gear on outgoing shaft got a K2-K6 shaft + new ball bearings.
4th and 5th will rev a little bit more than the earlier K.
I think it will it be like 4-5 run 17:18 when using 18:48 sprockets.
2-4 now undercutted so just waiting for a refurbished primary chain hub with new rubber inside.
Later outgoing gear is different and must be used with later transmission.
Photos before gear swap to earlier shaft.
Here K2-K6 shaft with later gear and new bearings mounted.
