Author Topic: Carb Vacuum Balance Port Repair Suggestions Please  (Read 1399 times)
Offline Scootch
  • Someday I'll know what I needed to know years ago
« on: July 05, 2022, 12:30:36 PM »
1970 CB 750 K0
So I have discovered that the vacuum port on one of my carbs seems to have the threads bunged up. I'd appreciate suggestions regarding how you would handle this.  TIA
Offline david 750f
  • 1976 CB750F
Re: Carb Vacuum Balance Port Repair Suggestions Please
« Reply #1 on: July 05, 2022, 01:07:34 PM »
Try a longer screw as the factory ones are very short. Gently run a tap through (5mm). I'm guessing it's just the first few threads that are buggered up.
1976 CB 750F
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: July 06, 2022, 09:40:10 AM »
I’ve thought about this in the past. Lots of bikes have permanent nipples, covered by a rubber cap when not in use. Next set of carbs I do, I’m going to find brass pipe the correct OD and thread one end to fit those holes. Cut them off short and red loctite them in place. Cover the ends with rubber, push on caps. When you need them, it takes seconds to install your hoses!
Clean out your buggered threads, make a small nipple, and permanently stick it in place. With a rubber cap, or course.
Offline Scootch
« Reply #3 on: July 06, 2022, 09:46:17 AM »
This is exactly what I was thinking!
« Reply #4 on: July 06, 2022, 09:48:23 AM »
Yes, my Kawasaki [w/Mikuni carbs] has this setup.  Handy...
Offline david 750f
  • 1976 CB750F
« Reply #5 on: July 06, 2022, 11:27:23 AM »
Motion Pro makes those permanent adaptors.
https://www.motionpro.com/product/08-0218
1976 CB 750F
Offline Scootch
« Reply #6 on: July 06, 2022, 12:18:13 PM »
Thank you very much for this !!  👍
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #8 on: July 06, 2022, 02:08:09 PM »
Rubber caps are on all post 1973 Z1 Kawasakis.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Rookster
« Reply #11 on: July 08, 2022, 07:16:51 AM »
I had the motion pro adapters with the rubber caps but I was never happy with the sealing washers.  They are a paper/fiber sealing washer.  I took them off and used the stock screws with the aluminum sealing washers the last time I did a sync a month or so ago.  I think the motion pro adapters allow air to leak past them.  They were convenient though.  The rubber caps would get really stuck on as well after a month or so.
Scott
Offline Scootch
« Reply #12 on: July 08, 2022, 07:33:17 AM »
Scott
Thank you for that info about the caps! I haven't received them yet but did notice that the fiber washers didn't seem like a good idea.
