« Reply #833 on: June 10, 2025, 12:57:12 AM »
Replaced the seals on my clutch slave cylinder on my Valkyrie. The cylinder itself isn't bad- three bolt and the line. UNfortunately, to get it off you need to remove the ENTIRE sidestand and, in my case, the center stand as well. It's been an adventure.
I've done a couple on 1500 goldwings so I know that we'll, though I didn't have to remove either stand. They have a charcoal canister that is tucked in tight between the clutch cover/slave cylinder and the centerstand that has to come out first that is a bear working on your back on the floor......
Logged
Stu
My current rides
Prior bikes....
