Author Topic: Cleaning cylinders after honing  (Read 1279 times)
« on: November 10, 2022, 10:00:49 PM »
Cleaning after honing...
https://www.enginelabs.com/news/what-i-learned-today-with-jeff-smith-cleaning-cylinder-walls/
I wonder how many shops who do boring and honing take the time to clean it up afterwards or if the assume that's the owner's job who is building the motor?
Valve grinding paste would be in this same camp...
Offline Steve F
Re: Cleaning cylinders after honing
« Reply #1 on: November 10, 2022, 10:46:11 PM »
If it's my engine, it'll get the thorough cleaning it needs.  Like the saying goes, "if you want it done right, you gotta do it yourself."
Valve lapping compound is scary stuff if you think about it.  I can't imagine all the havoc it'll create if it gets on the crank journals and mains.   :o
« Reply #2 on: November 11, 2022, 01:14:05 AM »
as stated never clean enough!dry compressed air aswell blows minute #$%* out of small cavities,wipe again with atf fluid untill it comes up clean.
Offline markreimer
« Reply #3 on: November 11, 2022, 08:01:08 AM »
I do an initial cleaning with brake cleaner or acetone in the shop, then bring it inside to my big laundry wash basin and use Dawn HD dish cleaner in hot water. Usually takes me three to five washes to get that white rags to come out white. I also struggle a bit with the iron cylinders flash rusting when I take them out of the hot wash. Compressed air might help. The heat naturally causes the water to evaporate fast but still have some issues here and there.
Then it’s a final clean with acetone or lacquer thinner. I give the cylinders, valve seats and guides a wipe with an oily rag if it’ll sit a while before startup. Which is basically always the case hah.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: November 16, 2022, 08:30:39 AM »
Made it a habit to spray everything with t-9 boeshield after a wash out.
Offline grcamna2
« Reply #5 on: November 16, 2022, 09:22:30 AM »
subscribed
75' CB400F/'bunch o' parts'
Offline Kelly E
  • Geriatric Hooligan
« Reply #6 on: November 16, 2022, 09:55:19 AM »
I wash engine parts in my solvent tank filled with real petroleum based solvent. Then I blow them dry with the air nozzle and rinse again with non-clorinated brake cleaner. I lost a cam and lifters due to grit on the first engine that I rebuilt. I didn't get the oil passages cleaned out enough. Ever since then I make sure all of the plugs get removed from the oil galleries so I can brush them out. The truth is that the rebuilder is ultimately responsible for the final cleaning before assembly.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
