Author Topic: Anyone used the over size piston sets from IMD piston in the UK?  (Read 2302 times)
Offline denward17
I am in process of ordering a set a of pistons.
Probably going with cruzinimage, but just learned of these.
Has anyone used them?
https://imdpistons.com/products/honda-cb750-sohc-piston-kit-4-new-392-410-high-compression?variant=32145858592881
Offline newday777
Re: Anyone used the over size piston sets from IMD piston in the UK?
« Reply #1 on: January 03, 2023, 06:08:22 AM »
Never heard of them.
Shipping costs from the UK to US is usually crazy expensive.  :-[
Stick with the CI set
Stu
My current rides
Prior bikes....
« Reply #2 on: January 03, 2023, 06:20:04 AM »
I have used the 550 ones and as far as i know the block i bored is going fine.
Offline denward17
« Reply #3 on: January 03, 2023, 06:35:21 AM »
It appears that if you buy them through ebay shipping is free.
Should we be concerned not knowing what the CI pistons are made from?
The IMD pistons are made from silicon aluminium alloy, but I don't know if that is good either.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: January 03, 2023, 06:46:45 AM »
It would be important to know material, forged, cast, etc.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #5 on: January 03, 2023, 08:45:52 AM »
Haven't quite a few  people here used the CI pistons here including Hondaman with a somewhat known track record of how to set them up etc.. ?
Offline denward17
« Reply #6 on: January 03, 2023, 09:31:44 AM »
yes, but always good to look at alternatives.
Offline grcamna2
« Reply #7 on: January 03, 2023, 10:09:06 AM »
75' CB400F/'bunch o' parts'
Offline Flyin900
« Reply #8 on: January 03, 2023, 02:29:40 PM »
I used the IMD pistons in my CL77 build recently and I am particular. I would choose the IMD over Cruzin Image. The Cruzin pistons are good quality, the rings not so much. Especially with the CB350F posts on this forum with many failures of the Cruzin image sets that seemed to be a ring quality issue.
My machinist is about as OCD as myself and was very impressed with the IMD product. Both the piston and rings quality. You can contact them if you have any questions, which I did and their response was timely and answered my bore and ring spec questions.
There are a number of US based sellers of the IMD products too, so if you contact them for that info I am sure they will refer you to a US seller. Not being US based, I bought directly from IMD Britain with no issues or shipping costs that were expensive.
« Last Edit: January 03, 2023, 02:37:07 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline denward17
« Reply #9 on: January 03, 2023, 02:42:06 PM »
IMD responded to an email I sent and said that their pistons were basically a 410 style piston.  I have the 392.
Can I assume the 410 style will not work in '78K cylinder/head?
Offline Nurse Julie
« Reply #10 on: January 04, 2023, 01:21:09 AM »
IMD are a reputable supply company here in the UK and I know people that have used their products. Although personally, we only buy piston/ ring kits from Cruzinimage. There was a conversation somewhere ( can't remember where) that IMD buy their standard Honda CB SOHC/4 products from Cruzinimage anyway. The parts definitely come in the same boxes that's for sure.
Trust me I'm a Nurse, I promise it won't hurt....much
Offline denward17
« Reply #11 on: January 04, 2023, 05:20:27 AM »
Ordered the CI piston set.....0.5mm over..
BTW, discovered that both Cruizinimage and IMD are both made in Taiwan.
« Last Edit: January 04, 2023, 06:05:05 AM by denward17 »
« Reply #12 on: January 04, 2023, 08:26:20 AM »
Use the stock wristpin clips just fore sure. About  $1US each, $10 for 8.
Offline Nurse Julie
« Reply #13 on: January 04, 2023, 08:36:40 AM »
I'm sure that would confirm what I said above, that IMD sell Cruzinimage parts.
It works out no more expensive for us to buy all our piston / ring kits from Cruzinimage, even though IMD are here in UK 🙄🙄🙄🙄. Cruzinimage customer service is excellent though and our stock usually only takes 4 working days to arrive from them.
« Last Edit: January 04, 2023, 08:38:56 AM by Nurse Julie »
« Reply #14 on: January 04, 2023, 08:58:21 AM »
Order a clutch set if yours are not new.
CI has good price on them.
Do not forget the tight TOTAL clearance bore-piston dia.
