Author Topic: K6 oil tank on a K2 hose routing  (Read 680 times)
Offline kurtkarram
« on: February 17, 2023, 08:30:50 AM »
Hello I have a 1971 cb750. I bought an oil tank for it on ebay, said 69-76. The tank is supposed to have 2 spigots: a small one to the back of the crankcase, and a larger one to atmosphere. The tank I was shipped looks like a k6 from what I read, as there is only 1 larger spigot at the bottom.
Will this work for my 1971? Do I connect this bottom spigot to the crankcase? What would be the best way to match the different size spigots if thats the case? I waited too long to get to this project, so I am unable to return it now.
Offline Shtonecb500
    • Youtube profile
Re: K6 oil tank on a K2 hose routing
« Reply #1 on: February 17, 2023, 08:46:24 AM »
the k1 tank should have a single spigot at he bottom and small diameter tube out of the back
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Old Scrambler
« Reply #2 on: February 17, 2023, 08:46:39 AM »
Hard to tell what you have..............but it reads wrong. A picture would help ;) Take a good look at the parts manual and the schematics available on this site.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: February 17, 2023, 08:51:08 AM »
Shtone...........................I've never seen a CB750 SOHC tank like that ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline kurtkarram
« Reply #4 on: February 17, 2023, 09:23:52 AM »
Here is the old and new tank. I had to buy a new one because I broke the threaded mount on the old one trying to take off the drain bolt so I can't reuse that.
« Last Edit: February 17, 2023, 09:25:29 AM by kurtkarram »
« Reply #5 on: February 19, 2023, 12:23:40 PM »
The K6 had the vent hose's pipe coming out the bottom, next to the oil hose bung. Honda routed the vent hose from the top rear of the engine over the airbox, then down to near the tank, then joined this breather to that vent hose with a tee, then ran the hose all the way back to the right passenger footpeg where it was held to that bolt with a small bracket.
On the K1 the upper vent pipe from the tank (by that separator, which is the big round thing on the back-top of the tank) went to a shorter hose that went directly down to the chain area (New Factory design) or else just straight down to in between the swingarm and rear of the engine (Old Factory/K0 style) where it spit on the rear tire, if the engine was foaming the (incorrect detergent) oil(!).
