Author Topic: Breather Tube Lines. Where do they go?  (Read 3097 times)
Offline John G
  • A 1975 CB Rebuild
« on: March 23, 2023, 10:07:58 PM »
The parts book shows #10 breather line tube. There are three breather ports as shown in the pictures but I'm not sure where they go.
« Last Edit: March 23, 2023, 10:24:51 PM by John G »
John G.
Re: Breather Tube Lines. Where do they go?
« Reply #1 on: March 23, 2023, 10:34:36 PM »
See pictures..
« Reply #2 on: March 23, 2023, 10:47:55 PM »
750 F s’  had this mounted up under the battery.
77-78k s’ may have also. Looks like they do..
« Last Edit: March 23, 2023, 10:55:54 PM by Tracksnblades1 »
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #3 on: March 24, 2023, 12:28:51 AM »
The Breather cover one just vents to atmosphere and the route depends on what CB750.
The pipe at the back of the engine is part of the chain lube and goes to the oil tank  ;)
« Reply #4 on: March 24, 2023, 02:19:48 AM »
What year, model is your bike John???
Offline John G
  • A 1975 CB Rebuild
« Reply #5 on: March 24, 2023, 10:15:30 AM »
Oops. It's a 1975 CB750K
John G.
« Reply #6 on: March 24, 2023, 02:03:41 PM »
Well my K5 is still tucked away for a few more weeks...
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #7 on: March 24, 2023, 04:43:12 PM »
Buddy of mine milled this to hold my carb vent tubes (1st pic)
2nd pic is the catch can I made up and mounted.
Still thinking about how I want to go about the vent tube at the back.
« Reply #8 on: March 24, 2023, 05:15:55 PM »
The late (post 3/75 or so) K5 and the K6 had a unique breather tube setup for the top-of-engine and back-of-transmission hoses. They joined together with a tee, then ran all the way back to the right-side passenger's footpeg mount where a little sheetmetal bracket held it's end way back there. Many of these have become lost when someone "customized" their K5/6. It's main purpose was to reroute the oil vapor away from the back of the engine where it would build up and be difficult to remove, which came from the original top-of-engine hose ending in between the back-of-engine and the swingarm crossmember. The engines in those bikes that were assembled with the complex and long hose(s) [mostly] have a smaller spigot on the back of the transmission: it is only 8mm in diameter while the normal ones were larger, like 10mm and even 12mm. This seemed to be a production prelude to using the PCV canister in the later bikes.
« Reply #9 on: March 24, 2023, 07:36:47 PM »
I'll have to look at the K6 in my shop as I don't remember that being the case on my original K6 of a hose on the right side pax peg dump.
I do have that on my K8 though.
I know that the K6 has a different oil tank vent design from the K5 I have (10/74).
« Last Edit: March 24, 2023, 07:38:31 PM by newday777 »
« Reply #10 on: March 24, 2023, 11:36:20 PM »
How does your “catch can” vent?
Offline Ellz10
  • ZZ
« Reply #11 on: March 25, 2023, 07:00:01 AM »
Hard to see in the pic, but I drilled holes in the top and situated a small bit of filter foam there.
« Reply #12 on: March 25, 2023, 07:31:17 PM »
Yeah, the K6 can have any combination short of the PCV valve: Honda had quit making the K5 when the F0 came out and sales went down something like 40% for the 750. American Honda was screaming loudly for the 4-piper again, so by (I think it was) November 1975 the K6 was re-announced. I've worked on K6 bikes with modified F0 wiring, K5 wiring harness with the little F box under the steering head added, F0 disk brake, and other odd things. Inside the engine it gets even stranger: there can be F0 type pistons, K or F cam, and -392- heads over K bottom ends, or even F bottom ends under K heads, with the 1st and 2nd gears of the K engine installed (come to think of it, that one probably had the 4th gear of a K engine, too). This last combination made for a doggy performer, though, with compression numbers like 105 PSI cold: it had the F cam in it, too, opening intakes at 0 BTC. The sparkplugs ran white!
« Reply #13 on: March 25, 2023, 08:13:29 PM »
I looked at the K6 in my shop and sure enough it has the top hreather tube running down and out the right side framework past the passenger peg.
« Reply #14 on: March 26, 2023, 01:56:06 AM »
K6 oil tank has no breather hose as the earlier.
The holder for the long breather hose from valve cover is rather expensive.
I lost mine many years ago.
Hose routed to passenger foot pegs.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #15 on: March 26, 2023, 03:19:48 PM »
I’ve put a bottle on for the cam cover breather. It’s probably overkill
Offline Ellz10
  • ZZ
« Reply #16 on: March 26, 2023, 03:55:41 PM »
Ooo Gamma, I see that brake arm conversion kit! How do you like it??
« Reply #17 on: March 26, 2023, 07:40:21 PM »
I'd bet $$ that if the EPA sees this, they will pass regulations to make all SOHC4 bikes have one...
Offline Translations
« Reply #18 on: March 27, 2023, 02:41:47 PM »
Speaking of breather tubes is there any concerns with just clamping a small filter on the nipple of the valve cover instead of routing a hose?
78' CB750F Super Sport
« Reply #19 on: March 27, 2023, 03:30:24 PM »
  A filter on the rocker cover will need cleaning once in a while. It will eventually oil soak from fumes. I tried venting the oil tank and valve cover into a high mount K&N type filter under the gas tank once. It was uneventful.
« Reply #20 on: March 27, 2023, 04:08:42 PM »
Good to know Don, with how easy it is to pop off and clean I am fine with that.
« Reply #21 on: March 27, 2023, 09:11:39 PM »
I saw small K&N filters direct on valve covers in the 80's.
It must smell when waiting for green light.
 Hose from valve cover going down to at least foot peg will make better.
The long hose routed back to passenger footpeg as my K6 had seems to be not available .
Offline Gamma
« Reply #22 on: March 27, 2023, 11:51:00 PM »
It’s not been on the road yet, hopefully it will be good. It’s a Suzuki GT750 brake cable
« Reply #23 on: March 28, 2023, 07:01:10 AM »
Does look really good, but curious why?
Thinking Honda wanted a metal rod to prevent possible liability from a cable break.
Offline Ellz10
  • ZZ
« Reply #24 on: March 28, 2023, 08:11:37 AM »
I'd be curious to hear your thoughts after a few trips!
I figured that was the only reason. I almost did one on mine, but opted to stay original there.
