Author Topic: What's a product I can use to clean this in my apt.?  (Read 1944 times)
Offline grcamna2
« on: May 06, 2023, 07:30:33 PM »
I live in a 2nd floor apartment(I don't have a shop)and need to clean the carbon off this piston:what do you recommend?
I scraped the majority of it off the surfaces so far using a dull razor blade.
« Last Edit: May 08, 2023, 12:13:03 AM by grcamna2 »
75' CB400F/'bunch o' parts'
Re: What's a product I can use to clean this in my apt.?
« Reply #1 on: May 06, 2023, 10:07:42 PM »
 Lava hand soap and a brush? Dishwasher detergent is pretty potent too.
Offline grcamna2
« Reply #2 on: May 06, 2023, 10:22:06 PM »
I don't have either of those Don.
How about Comet & a toothbrush ?
Offline rluser
« Reply #3 on: May 06, 2023, 10:32:53 PM »
Hoppes #9 and a toothbrush.
Online Alan F.
« Reply #4 on: May 06, 2023, 10:57:18 PM »
Would a soak in baking soda and water loosen that carbon? It works on baked on carbon cooking pans... Cheap too.
Offline simon#42
  • liverpool
« Reply #5 on: May 06, 2023, 11:27:17 PM »
you can buy very cheap ultrasonic cleaners on amazon . they are only small but after you have cleaned the piston you will find at least another 100 things to clean in it .
Offline grcamna2
« Reply #6 on: May 07, 2023, 12:23:25 AM »
« Reply #7 on: May 07, 2023, 09:13:57 AM »
Oven cleaner spray?
Offline jgger
« Reply #8 on: May 07, 2023, 09:22:06 AM »
I don't know if it will work on carbon, but for oily or greasy stuff Dawn in the spray bottles is my new go to. The new  "spray and wipe clean" stuff, not just Dawn mix in a regular spray nottle.
« Last Edit: May 07, 2023, 09:24:21 AM by jgger »
Offline grcamna2
« Reply #9 on: May 07, 2023, 09:33:50 AM »
I had hit it with a 1/2 can of spray carb cleaner yesterday;it helped soften the stuff up a bit.
I have it soaking in baking soda now.
« Reply #10 on: May 07, 2023, 09:52:43 AM »
Drive chain cleaner spray and a metal brush on a drilling machine.
Doctor at work ;D
Offline grcamna2
« Reply #11 on: May 07, 2023, 10:40:12 AM »
Okay,the Seafoam deep creep is strong stuff and should melt this carbon;I'll use a firm 'tooth brush'.
I was running a main jet that was too rich for a few thousand miles..,plus my crankcase breather is the type that feeds itself right back into the air filter..:I plan to change that by installing a K&N breather filter.
« Last Edit: May 07, 2023, 12:59:53 PM by grcamna2 »
Offline grcamna2
« Reply #12 on: May 07, 2023, 11:11:53 AM »
I'm impressed with how well it's working after only 2 hours;I rinsed it off and reapplied it,will do a hot water soak of it a bit more.
I can also rinse it down the sink when I'm done.
« Last Edit: May 07, 2023, 11:20:33 AM by grcamna2 »
Offline grcamna2
« Reply #13 on: May 07, 2023, 11:14:26 AM »
Doctor at work ;D
Looks good Per.
Did you remove the rings also? or were you only needing to clean the domes ?
I like those chromoly cylinder studs;is this for your 1000+cc engine ?
« Last Edit: May 07, 2023, 11:37:17 AM by grcamna2 »
« Reply #14 on: May 07, 2023, 12:45:07 PM »
Only dome cleaning, covered rings and engine to avoid carbon particles in there. The 2 inner studs for oil transport to head especially.
I did not want to take off rings when not needed if one will snap off.
I just remembered that I had used my electrical toothbrush for cleaning an engine part once.
Braun Oral-B. Used an old brush. It worked really fine with  its vibrations ;D
Dirty jobs possible if cover it with a plastic bag, only brush sticking out. Maybe another time.
The studs are Kibblewhite.
Yes, engine for 1005cc 71.25mm cylinder (Billet block), now stock cylinder with 970cc,  70mm pistons on the photo.
Billet block might go back on later or on another build where it fits too. Its pistons are now gas ported, horisontal. I'm eager to find out how that will work. The 970cc setup work too good to take apart.
« Last Edit: May 07, 2023, 12:51:04 PM by PeWe »
Offline grcamna2
« Reply #15 on: May 07, 2023, 10:42:35 PM »
The piston has cleaned-up with 6 hrs. soaking in baking soda and some scrubs with it using a toothbrush.
« Last Edit: May 07, 2023, 11:09:43 PM by grcamna2 »
Online Alan F.
« Reply #16 on: May 08, 2023, 08:12:31 AM »
And it probably cost pennies at most, used no electricity, didn't require a trip out to buy anything, no need for safety equipment, produced no fumes or dust, and left the part shining.
Bill wins.
Online Stev-o
« Reply #17 on: May 08, 2023, 08:54:44 AM »
What bike is that for Bill?  Missing 3 more!
Offline grcamna2
« Reply #18 on: May 08, 2023, 11:57:43 AM »
Stev-o,this particular piston(63.25mm)is for my 1979 Honda XR185 dirt bike engine,.25mm oversize.
« Last Edit: May 08, 2023, 11:59:45 AM by grcamna2 »
Offline grcamna2
« Reply #19 on: May 08, 2023, 12:04:49 PM »
Bill wins.
Alan,I feel good about using this procedure again for other bikes which I want to clean the carbon.
I would prefer vapor or very fine glass bead blasting which is quicker;it's on my wish-list  ;) when I get myself a Real Shop w/ 'all the fixins'  ;D
Online Alan F.
« Reply #20 on: May 08, 2023, 01:05:48 PM »
You and me both Bill.
« Reply #21 on: May 08, 2023, 04:42:16 PM »
Congrats Bill... Nice outcome
Offline grcamna2
« Reply #22 on: May 08, 2023, 05:27:49 PM »
I like how it came out w/ just light applications of a standard toothbrush which I spent the most time with in the ring lands. The rings are still good and they moved very well so I will re-install them with the same orientation of gaps as before and leave the cylinder alone. I would normally have used a piece of broken ring to removed every last bit of light deposits that're left at the bottom of the middle ring,but I don't have any broken rings left.
I was curious if anyone knows whether a stock set of 4) XR200R 65.5mm pistons would be useful for a CB750 for a big bore? I imagine the deck-height isn't compatible.. although the wrist pin is the same @ 15mm on them.
Online Alan F.
Offline grcamna2
« Reply #24 on: June 04, 2023, 07:21:20 PM »
Check this out:
https://www.instagram.com/reel/CqQipwHpr_B/?igshid=MzRlODBiNWFlZA==
I didn't dig too far into that video,but it looks like that last application from the cup onto the tissue papers worked the best.
